Results 1 to 25 of 29
warped rotors???
    Sep 2006
    Around the corner
    warped rotors???
    While under moderate to heavy braking, I am getting a vibration from the front end.
    the pads have about half life and the suspension is balanced to where I like to ride it. the rotors seem ok, the question is ... can a warped rotor cause this vibration?
    It's frequency is some where between the engine and the road and only happens some times under the mod to heavy braking
    I thought about wheel bearing but when lifting the front end there is no obvious bearing play
    any sugestions ....
    The rule is:
    warped rotors???
    warped rotor or maybe bent wheel
    Never Enough HP kawi997's Avatar
    May 2007
    Uxbridge, Ma/ Center Barnstead, Nh
    warped rotors???
    i'd go with the warped rotor first, how bout when you come to a complete stop. do the brakes grab very suddenly when almost completly to a stop?
    Lrrs# 997 Ameture
    03 DUCATI 749S(Race)
    06 Chevy Cobalt SS
    Sep 2006
    Around the corner
    warped rotors???
    if that is possible the alloy of the wheel would not re shape sometimes and not others. seems to be ride distance and speed related
    like the rotors or pads are cold
    can the rotor loosen from it's mount?
    The rule is:
    Sep 2006
    Around the corner
    warped rotors???
    nope they brake with normal feel
    The rule is:
    Sep 2006
    Around the corner
    warped rotors???
    even with the vibration I flogged the shit out of it in VT this weekend and found no issues even when the appalachin gap had me on the brakes hard most of the way
    but then when I rode to work monday ...DUN DA DAH the vibration came back
    The rule is:
    May 2007
    warped rotors???
    hmm. i'd have to say its the rotors, then. they do tend to vibrate like that when they are becoming warped. very rarley do they come loose if they have never been touched before, and if the bike never had any dumps. but hey try tightening em up. i'm having that same probs on my duc at the moment. sucks rotors are so exspensive now.
    Lrrs# 997 Ameture
    06 Chevy Cobalt SS
    Sep 2006
    Around the corner
    warped rotors???
    Quote Originally Posted by kawi997 View Post
    never dumped this bike. How do you tighten the rotors????????
    The rule is:
    May 2007
    warped rotors???
    is it the cbr?
    Lrrs# 997 Ameture
    06 Chevy Cobalt SS
    Sep 2006
    Around the corner
    warped rotors???
    is it the cbr?
    yup it's and early 04 the tag reads 12/03 mfg date
    The rule is:
    Sep 2006
    Around the corner
    warped rotors???
    I am riding it like normal but in the back of my mind I have this strange thought that one of these times I going over the top becuse the brakes locked up
    The rule is:
    May 2007
    warped rotors???
    ok then all ya gotta do is take an alen wrench, or socket and tighten the bolts at the bottom of the rotors until bottomed out then give a little extra crank to make sure there tight. you dont even have to take the wheel off. just go around the rotor and hit each bolt. i think there alens on your bike. most are.
    Lrrs# 997 Ameture
    06 Chevy Cobalt SS
    Sep 2006
    Around the corner
    warped rotors???
    The rule is:
    Sep 2006
    Around the corner
    warped rotors???
    These are the ones that are held in by small cock ring things kinda like a press fit rivet
    The rule is:
    May 2007
    warped rotors???
    i'd also suggest takeing a flat head and wedging it between the pads and the rotor from the top of the caliper and seperating then. what your trying to do is depress the pistons into the caliper. then bleed your brakes. this will help with the nonsence.
    Lrrs# 997 Ameture
    06 Chevy Cobalt SS
    May 2007
    warped rotors???
    look farther down closer to the axle.
    Lrrs# 997 Ameture
    06 Chevy Cobalt SS
    May 2007
    warped rotors???
    two piece rotors have those cock rings in the mid of the rotor lol
    Lrrs# 997 Ameture
    06 Chevy Cobalt SS
    Sep 2006
    Around the corner
    warped rotors???
    I'm going to stroke my throttle body for a while .... I am going to nhis monday and would like to prep the bike of all thes little things this weekend ... I'll check back
    The rule is:
    Sep 2006
    Around the corner
    warped rotors???
    it's fun to say cock ring
    Thanks K wacka
    The rule is:
    May 2007
    warped rotors???
    alright man get er dun
    Lrrs# 997 Ameture
    06 Chevy Cobalt SS
    Lifer Wishbone's Avatar
    Jul 2006
    warped rotors???
    Pull your pads and give them a quick scuffing with so fine sand papper and then hit the rotors, this will get off the glazing and should be done every 5-10k miles. then bleed the lines.
    If that doesn't work ask Pat because every one knows that he knows every thing
    warped rotors???
    Front vibration can also be caused by a loose steering head bearing. (thanks to Degsy for that little tidbit of info.)
    Sep 2006
    Around the corner
    warped rotors???
    Thanks Chuck i mean Degsy through Chuck
    The rule is:
    Jul 2006
    warped rotors???
    The difference is where the "feel" comes form but it is tough to discribe
    The best way to check the steering head bearing is to put it on a front stand (pin type) sit on the bike and slowly move the bars back and forth to try and feel a "click" make sure no cables are binding and make sure it is smoth
    warped rotors???
    Quote Originally Posted by fasterthanu View Post
    This might not detect it, since the triple type front stand rests on the bottom of the triple and effects if the steering head will move back and forth or not.
    The best way is to get the front end off the ground and not supported by anything and the bike supported on jack stands (usually under the front part of the engine somewhere.
  1. SHORT NOTICE WARPED TOUR 7/13/11
    By Dannyf in forum For Sale
    Last Post: 07-11-11, 10:30 PM
  2. Is a rotor warped?
    By BMFR6 in forum Bike Maintenance
    Last Post: 05-10-07, 07:48 PM
  3. Terribly warped rotors. Opinions?
    By 13 in forum General Bike Related
    Last Post: 08-30-05, 04:43 PM
