OK, riding two up today, I noticed a weird noise when accelarating hard in low gears. For example, when leaving from a stop light, release the clutch and get a few MPH before really accelerating hard (a good hard pull on the throttle, 1/2 full turn) and I noticed a bit of a clatter and briefly it feels like the bike bogged a little bit during the 'clatter'... Can get the same affect in second gear as well right after the shift, if you give it a good handful of gas.
I've never really noticed this particular phenomena when riding solo.... If it means anything, its an EFI bike.
Just curious as to any thoughts what might cause this...
Cheers,
Chris
Sounds like detonation. Heavy load, low RPM's (well below where the motor makes any torque or horspower) , good amount of throttle. Try going up to the next higher octane rating on your gas and be easier on the throttle when riding two up until you get the R's up.
Cheers, Lee S.
I know i'm slow, you don't have to rub it in.
Why, Yes! I do think you're a Wanker!
EEP! Running 93 octane now, but yeah, it is low RPM, not anywhere near the real power band of the bike...
Cheers,
Chris
If it is detonantion it might be a bad knockor O2 sensor causing a weird signal to go to the ECU. The dealer should be able to scan the code for you to see if it is within spec. Good Luck...
SSearchVT
Well, hopefully the diagnostic software/cable for my bike should be arriving today or tomorrow so I can read any and all codes to check it out...
Cheers,
Chris
