Results 1 to 6 of 6
Fuel pump relay blowing
    Winter sucks Nate Dawg's Avatar
    Providence
    Any ideas what may be causing it?
    At the NJMP the gsxr started to sputter then just shut down. I could start the bike, give it some gas. As soon as I put it in gear and gave it some throttle it would die. When I was in the pits, I heard a pop in the tail of the bike. After that the fuel pump wouldn't prime. When I got home and replaced the fuel pump relay with a new one. The bike started then died again. Now the pump isn't priming again, becuse the relay is blown.
    So.....?
    08 Ape RSV1000R
    09 Ram 1500 Black Big Horn
    10 Mini Cooper S sleeper (hers)
    Re: Fuel pump relay blowing
    You may have to chase all the wires that lead to and from it??? Poss when you put the new harness in there was a routing spot that has worn thru and grounding out the relay...
    Providence
    I hate electrical shit!!!!!!!!!!!!!!!
    08 Ape RSV1000R
    Did you pinch the replacement one you put in anywhere?
    Only something drawing on the relay can blow the relay.
    Check the ground for the fuel pump and check/swap the fuel pump.
    d
    Well, I tried. Bad guess, I guess.
  1. CBR 600 F4i - No Fuel Pump Prime
    By kb1 in forum Bike Maintenance
    Last Post: 03-29-12, 02:52 PM
  2. i need a fuel pump!!!
    Last Post: 06-05-11, 08:27 PM
  3. Not the fuel pump
    By Nate Dawg in forum General Bike Related
    Last Post: 08-10-08, 08:05 PM
  4. fuel pump???
    Last Post: 08-10-08, 12:54 AM
  5. Fuel Pump Testing
    By ZX-12R in forum Bike Maintenance
    Last Post: 04-28-07, 05:22 PM
