Results 1 to 11 of 11
Fuggin' Tires...
    Fuggin' Tires...
    My rear rain tire won't hold air. I mounted 'em myself last year, but never got to using 'em. I had 'em in a heated area pretty much all winter. I changed the valve core thinking that may be where it was leaking from. Nope...
    I tried the soapy water thing too, but can't seem to find where it's leaking from. It's a brandy new tire too...
    I'm thinking maybe I should try to find a shop that'll break the bead and try to reseat it? I dunno, but I'm running outta time here!
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    break the bead go 2 auto parts store
    get a can a bead seal works good
    my boy try please
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    Fuggin' Tires...
    lol
    camel makes the stuff
    www.bostonmoto.com
    Forum Rules
    Northshore/Beverly, MA
    Fuggin' Tires...
    if you can't find the leak with the soap and water...I'd look at the rim itself, could have a crack in it.
    Fuggin' Tires...
    The wheel itself held air when JC had it...
    Fuggin' Tires...
    Fill up the bath tub and put it in there...you'll find the leak...
    Re: Fuggin' Tires...
    Fuggin' Tires...
    Then you got Squirrels letting the air out of the tire when you aren't looking....
    NOT laughing with you {~; bemused's Avatar
    Deer Island, OR
    Re: Re: Fuggin' Tires...
    squirting soapy water w/ a spray bottle? or full-immersion, like Mark suggested? this quote don't make it clear, kemosabe...
    jeff f
    '97 RF900R
    Fuggin' Tires...
    Are you checking for leaks with the soapy water with air in the tire You did say they don't hold air
    Even the ever so smallest leak will show up with the soapy water and spray bottle trick, that is of coarse if there is air inside it that has a higher presser than the air outside it
    Deer Island, OR
    Fuggin' Tires...
    true, true... but it can be a helluva lot easier to find a small / slo-o-ow leak in a wash bin or tub, IMHO.
    jeff f
    '97 RF900R
  1. Fuggin cop
    By Wishbone in forum General Bike Related
    Last Post: 09-24-09, 06:49 PM
