Page 4 of 4 FirstFirst 1234
Results 76 to 95 of 95
Winter Projects - what's on the agenda?
  1. #76
    Re: Winter Projects - what's on the agenda?
    That thing is cool...if you aren't already aware, lucky6600 (Ching) over on band of riders is a pretty knowledgable dude about these and has many, many posts and pics about those type of restorations, so check him out if you need any help with sourcing parts or general info.
    I second this. Ching is the man with old BMW's.
    Band Of Riders
    Member Tiller Ayuh's Avatar
    Greater Portland, ME
    Thanks for the heads up, I will probably check him out as I know I'll need some help!
    Cheers!
    Chris
    07 Ducati 999S Team USA
    04 Ducati ST3
    66 BMW R50/2 - Project
  3. #78
    Quote Originally Posted by Tiller Ayuh View Post
    Cheers!
    Chris
    He's married. So don't look too hard.
    Shut up. Let's go skiing.
    cannon tuesday. 2-for-1
  5. #80
    Jun 2005
    Oh, yeah, who doesn't have Tuesdays off...
    all the people that will be there do
  7. #82
    All 50 of them
    more snow for me
    less waiting in line
    less $$
    all wins.
  9. #84
    What should I do with the KTM suspension?
    The bike has a shade over 200 hours on it, and I'm probably responsible for ~30 of those hours. Judging by the maintenance habits of the previous owner, it probably has olive oil in the forks.
    I rode the KTM at the Stimilon challenge and at another MX track, but since I got the CRF I much prefer using that for MX. So, the KTM will stay a woods bike.
    What should I do with it -- just a respring and maybe a revalve? AFAIK it has stock KTM suspension front and rear, and an aftermarket steering damper in the bars.
  10. #85
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Depends how much you wanna spend. Refresh both ends for roughly 400. Springs and revalve double that or even more if you go with an expensive shop like factory connection. Its possible you could be somewhere in the middle, like valving is ok but a spring change is warranted...but you arent far off "average" weight so maybe not even springs. One of the problems with newer riders ordering suspension service is that you probably arent able to describe current suspension shortcomings very well to the tech.
    If I think im going to keep the bike for a long time, i bite the bullet and do springs and valving right away, and then it can just be refreshes from then on.
    My advice, definitely get it serviced at a minimum, check charts and sag range to see how necessary springs are, and then if money is tight, wait to revalve until you ride it for a (long) while with fresh oil and seals. If its running on olive oil now, even a pro test rider wouldnt be able to adequately give feedback for valving, and since its a ktm woods bike being used for woods, the valving probably is not holding you back much. Proper springs (and shock sag and fork height settings) are very important, though.
    Ive had great luck getting phone advice from factory connection..,
    +1. if it feels OK in the woods now, set your sag and have both ends refreshed. it won't be cheap but it's well worth it. seals, bushings, etc will prob need attention in addition to fresh oil. once you set sag you'll know if you're far off on springs but like Gary said, chances are you're fine for right now.
    i just had Motoworx revalve front and rear on the RR, Rob was awesome to deal with... bike is in pieces so won't know how it performs just yet.
    The Honda is going to Factory Connection as its got FC internals already and they will revalve it for free. It's not cheap, though
    I appreciate your estimate of my weight, but uh, I'm just under 230lbs without gear so I'm probably far enough over "average" that a spring shock would help. From memory, actually, the bike already has a heavier spring in the rear shock, but I have no idea about the fork springs.
    And yes, not being able to adequately describe what I like and don't like about the suspension sucks. As a new rider this is probably more of an issue in MX for me.
    Yeah, I think this is the best advice. I might go to Factory Connection the first time and then just get by with cheaper refreshes later.
    Because it's woods, is valving less important because all the speeds are lower? Or because the impacts are smaller than (say) MX?
    I'll add them to my list, thanks. I was thinking of GMD Computrack as well but I don't know if they touch dirt bikes much, if at all.
    I'd love to learn how to do basic suspension refreshes myself but right now I just don't have the time.
  13. #88
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    FJR
    -Valve check
    -Secondary air system removal
    -Shorai Battery
    -Slip-on
    KTM
    -Fork oil
    Oct 2008
    NW CT
    The ground speed may be slower, but the suspension needs to react faster when hitting sharp objects in the woods.
    Sep 2012
    Southwick,MA
    I had my KTM suspension at Factory Connection shortly after buying the bike used, and I'm happy with what they did...I got springs but not valving, probably wish I did both (it had a revalve done by someone else thru prior owner, but for tight woods and that's not really what I'm using it for now).
    If you weigh 230, you definitely need non-stock springs.
    FC has some selling points that others don't, regarding you and your KTM...first of all, they do so many of them that they should have a good idea of how to improve the suspension on your particular bike, regardless of your ability as a test pilot to tell them what it needs, and second, last I checked they had some special inside relationship with WP, who I think manufactured the shock on your bike.
    There's a whole voodoo component to suspension; anyone can set up shop but I give a serious raised eyebrow of skepticism when some dude out of his garage claims he can improve the valving over what KTM engineers did, without ever riding the bike before or after service. In other words, at some point, you write a check of trust (along with money) to whoever you choose. FC isn't cheap, but I have had good results with them both in terms of advice and results, at least on dirt bikes. I've had great results from GMD computrack for road racing stuff, too. He might do off road, Probably does, I know PK rips offroad himself so I doubt he hires out his own stuff!
    I just sent my forks to FC because I have the dreaded '14 4CS fork. They benefit from extensive mods and FC has a lot of experience with them. It was expensive, but their service was insane. I shipped them out thursday night, and had them back saturday afternoon. I have only ridden ice on them, but my be getting out on dirt pretty soon!
    Normally PK does my dirt stuff. This was a one off due to the development time FC has in on these forks.
    Sep 2012
    Southwick,MA
    PK has been awesome to me when I've used him; wanted to mention to Number 9 that I only brought it to FC this time because of the KTM/WP connection and because I was in a rush so I was able to get same day service at one of their vans at a dirt track day.
    Thanks guys. The Honda suspension is done, it came in about $50 less than quoted. The KTM isn't done yet, the upper fork tube needs to be replaced due to an incredibly poor repair job by the previous owner. It looks like the tube was cracked somehow and it was welded up badly. Not sure if I'll go for a new tube or get a set off eBay and salvage those..
  19. #94
    Quote Originally Posted by Tekime View Post
    Just curious what you guys/gals have planned for the winter.
    Going through a 1975 BMW R90/6 so it will be trip ready. Just sent off the tach and speedo to a specialist for inspection and rebuild. Some other fiddly stuff.
    Gotta get the Triumph out of the shed and go through the wiring. Something is killing the battery after a few days. And replace the front brakes.
  20. #95
    Mount 2 sets of ice tires
    Ice ride at least 5 times
    Suspension freshen up on 675 (sort out bottoming front end)
    Ride around Guatemala
    Revisiting this thread, I completed my agenda! Despite the weird weather, I rode ice more this year than ever before. I sorted my 675 for good by selling it and getting an R6. and Guatemala was over the top. All time. Gorgeous, challenging, fun, and a free trackday to boot!
    I'll call that a successful off season.
  1. cleaning out to many projects
    By vintage ex race in forum For Sale
    Last Post: 01-09-10, 11:43 AM
  2. Weekend Projects.
    By LM954RR in forum Pit Area
    Last Post: 01-25-04, 10:50 PM
