Results 1 to 9 of 9
Woodsmen...& ladies lets talk psi
    Member jayth's Avatar
    Aug 2009
    N.H.
    Just Got done with some dirty riding On a T TR 230 track was mostly loose...read golfball to football sized rocks disbursed with nice sections of muddy wet grass... on the golf ball stuff The front end washed frequently And was honestly downright unsafe... i had 20 PSI in the front and 20 in the Rear so the question is did I have too much up front... Or is this just a really tough track
    Re: Woodsmen...& ladies lets talk psi
    Wow, I've been running 12 to 14 psi normally. 20 sounds way high. What tires are you using?
    Aug 2009
    N.H.
    I believe you just answered my question but, Yes the tires are cheap, Brand Nu on the front one season on the rear... Both are Shenko's (sp?)
    Central MA
    +1
    Pretty high. Try 12 psi and report back.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    12-14
    Aug 2009
    N.H.
    Thanks For chiming in... I knew I had it fucked & up I will try lower pressures from here on in...
    I agree with everyone, your air pressure is way to high. 12-14 seems to be the average, I run about 10PSI rear and 12PSI front around my place. I've read several psost on dirtbike forums where guys run as low as 8psi with heavy duty tubes and 2 rim locks, with good results.
    For what it's worth, you'll never have a planted feeling riding on lose rocks. Proper tire pressure and proper suspension set up should help
    12-12. You can go lower with a trials tire.
    Central MA
    Or with HD tubes.
  1. Lets talk brakes...
    Last Post: 10-25-10, 08:33 PM
  2. Lets talk new gear!
    Last Post: 01-28-10, 10:25 AM
  3. ok lets talk buying 600
    Last Post: 04-16-04, 05:22 AM
