LRRS 878 Clapped out Gixxah
Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
Wow. Thats sick.
Steve
Work Hard---Play Harder
thats insane
amazing to see the springs and cap rotating around like that.
It really is, at first I thought it was the sample rate of the video playing tricks on me and then i noticed the marks going around. Does that mean that the springs are literally floating for a moment as the lobe comes off the peak (correct term?)
weird shit happens during vibration.
Steve
yeah, my thoughts exactly. It's nuts how much the springs rotate. It's amazing that the little tiny keepers stay in place though all of that.
Oil is an amazing thing, too... imagine the speeds and forces there and then try to imagine what the big end of the con rod is going through...
Neat, I love the way they moved the cams toward the middle of the head and made the lobes smaller by using the lever of the cam followers to increase the lift. Also, using followers completely does away with having to engineer the valves/springs/keepers/retainers for side loads (the sole purpose of "buckets") since all the side loads are applied to the followers, which can handle it with no problem at all.
How is valve lash adjusted on this engine? There's no bucket and I can't see any screw/locknut. There's a ton of articles on the web about how innovative the valve train is, but I cannot find any that mention adjustment. The only place I could envision a shim is right on top of the valve retainer, centered on the valve stem.
I think you have it nailed, small shim between the follower and valve stem, hiding in a recess made by the spring retainer cap. There are SOHC 4v heads for pitbikes that use a similar setup.
I read that they run the cam chain from a gear driven shaft, rather than directly off the crank. This allows for a much shorter cam chain and raises the resonant frequency of the chain itself. I imagine this dramatically reduces the cam chain tension and the friction of the chain on the chain guides. Very cool.
I think it's pretty widely known that Ducati uses desmo gear on their MotoGP bike for marketing purposes. There's no advantage to it but they need to keep using it to justify using it on their street bikes. It's neat engineering, but it complicates things that don't need to be complicated. I imagine the dealerships love it due to the maintenance revenue it generates.
I rather like how BMW simpified and improved an already simple design. That was clever.
Yes, it's of such little value that Honda hasn't been petitioning for RPM caps as a way of knocking Ducati down a peg in Moto GP... : )
Either way, with the way technology rapidly moves from MotoGP to street bikes, it really does not matter who wins the races, we all benefit from the competition. There are not too many motorsports that have such rapid movement of full-on racing hardware to off-the-shelf OEM street hardware. Gotta love that. With the new 2012 MotoGP rules, the technology will trickle down to the street even more quickly.
Cool video, though i think a similar vid with an R6 going 4k rpm more than that would be more impressive![]()
