Results 1 to 20 of 20
WT borrow gps lap timer
    im headed to NYST on friday and im wondering if someone has a GPS lap timer i can borrow.
    Re: WT borrow gps lap timer
    take mine oxx. but you'll have to meet me somewhere in the middle
    Rochester, NH
    I have a GPS logger you can borrow.
    Roland Arsenault
    LRRS and USCRA #763
    Quote Originally Posted by Jimmy Faceplant View Post
    youre not going?
    youre not going?
    No. Do you want my Qstarz and laptop?
    Wirelessly posted (GS3)
    Roland is hooking me up. Thanks though.
    Don't be like me: figure out where the on-off switch is BEFORE you head out on track.
    Actually.. just leave it on. I borrowed his gray timer last Friday. (Thanks again man!) I kept turning it on and off again between sessions. I either got the switch backwards and kept turning it off-instead of on-when heading on track. Or it overwrote the previous session each time I power cycled it. But either way, Roland only had data for the very last session of the day.
    It seems these gadgets can be left on all day without issue. Probably a safer bet.
    I also mounted it such that the POI button got mashed a lot. Don't do that either.
    WMC original sdog30's Avatar
    Burgy
    You can always use mine, Ox.
    If I run it, I'll be in intermediate anyways, so we can keep swaping it back and forth.
    LRRS/CCS #66
    i dont want you taking credit for my faster lap times
    Jan 2010
    Farmington, CT
    QStarz 1000EX will fill up the storage space, if you get lots of track time during a Track Day. I suggest making sure it is cleared of data & fully charged prior to starting the day & downloading the data a Lunch break, clearing the data & should have enough space to finish off the day. Yes, just leaving it turned on is a better bet, since it goes into Power-save mode & wakes itself back up with movement.
    The 6000 model will hold plenty of laps, but also needs to be charged fully to ensure good battery life. This model also works best if you enter a Beacon file with multiple segments for a given track ahead of time, to get best overall ideal optimum lap time, otherwise it just keeps track of full laps, without segment times.
    Rochester, NH
    And here are the results of your top 3 laps for that one session you did use the GPS!
    WT borrow gps lap timer-2013-09-21_nyst_brian_oxx_top3-jpg
    (Higher res version)
    Last edited by rolker; 10-10-13 at 01:25 PM. Reason: Added link to high res version of graph
    Roland Arsenault
    LRRS and USCRA #763
    Quote Originally Posted by rolker View Post
    And here are the results...
    We seriously need to turn your script into a web app. Just sayin'.
    Rochester, NH
    I've got the guts ported to Google App Engine, now I just need to look at the UI portion...
    Roland Arsenault
    LRRS and USCRA #763
    You've met a guy that could theoretically help with that. He's got incentive now too.
    Rochester, NH
    Now that racing is done, I might have time to revive this little project. Do you know WebGL? Of course, I do need to rebuild by 125 motor over the off-season, but that should only take an hour...
    Roland Arsenault
    LRRS and USCRA #763
    No.
    thanks roland. im guessing the red line is a little glitchy because there is no way i was almost stopped at one point and still did a 1:41
    not as smooth of a graph as i expected but cool nonetheless
    Rochester, NH
    Where did you have the GPS mounted? Did it have a clear view of the skies? Any section of the track "shaded" by tall trees or something? I'm guessing a momentary weak gps signal might have cause the few little glitches.
    Roland Arsenault
    LRRS and USCRA #763
    Mounted on the top triple tree.
    Rochester, NH
    I usually got cleaner data by mounting it on the tail.
    Roland Arsenault
    LRRS and USCRA #763
  1. GPS Lap Timer
    By loudog in forum For Sale
    Last Post: 02-05-12, 02:09 PM
  2. Replies: 23
    Last Post: 09-03-09, 07:32 AM
  3. GPS as a lap timer...
    By Manny in forum General Track Day Talk
    Last Post: 01-05-09, 11:52 PM
  4. Lap Timer...
    By Stoneman in forum Pit Area
    Last Post: 08-14-03, 07:55 AM
