Results 51 to 75 of 76
where do y'all get your Pirellis?
  1. #51
    Re: where do y'all get your Pirellis?
    Yeah... as Paul mentioned... on some of these newer tracks, the asphalt has such sharp edges and great grip... that you can run at higher PSI. Our suggestion is to use the Pirelli recommended numbers I posted first... then adjust according to your tire and grip and tire wear.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
  2. #52
    Lifer Pittenger5's Avatar
    Austin
    The amount of tread rubber left is the marker for how much useful time a tire has. The less rubber, the less heat, the less grip.
    Wait ... is this true? Is this why tires "go off"? Been trying to wrap my head around this concept for years, is it really that simple?
    Zip Tie Alley #505
  3. #53
    Hiram, ME
    Yup. Obviously, other factors can contribute to a tire losing grip over time, but this is a(the?) big one.
    Austin
    Interesting. Do you know of any data that shows the heat difference between a new tire and a shagged one?
    Zip Tie Alley #505
  5. #55
    Hiram, ME
    I don't have any that we've collected, no. If you've ever seen a cross section of a worn out DOT tire, the thin layer of tread rubber is pretty obvious.
    Austin
    Interesting. Good to know!
    Zip Tie Alley #505
  7. #57
    We should cut up a used tire, compared to a new.... it's amazing how thin the rubber gets when you get past the wear bars. In addition to the temperature issue, the remaining rubber is just so thin that it doesn't "act" correctly either.
    Tony
  8. #58
    Race rubber is already incredibly thin, even when new.
    Cut open a uses sport touring rubber too.
    Nov 2009
    Bristol County
    I wonder if the marketing departments already make something like that? Like those display things you see in doctor's offices?
    nedirtriders.com
  10. #60
    yeah... it's probably out there somewhere. Fortunately, tire use is sort of self-monitored. Even without looking at your tire, you'll notice the degradation in performance (assuming you are using a race tire's abilities)
    Tony
  11. #61
    Jan 2012
    Who's giving up a new tire to cut 🤣
    Sent from my Pixel using Tapatalk
    Quote Originally Posted by caloots View Post
    Who's giving up a new tire to cut 藍
    Maybe a Dunlop...
    Maybe a Dunlop...
    Let's not start that whole mess now!
    Tony
  14. #64
    Hahaa! Oh right, sorry! it was a joke because I actually have some on my new bike. But I surely intend to ride them before any cutting.
    Who's giving up a new tire to cut?
    Kurtz. He says he got a steady supply. Also, he started this thing, he needs to finish it.
  16. #66
    Hiram, ME
    Ha!
    Lifer Karaya One's Avatar
    Springfield, Mass
    Kurtz - nice explanation on heat cycling. We still get those questions, too. It truly is a non-factor now with modern compounds. What kills a race tire is racing. Nothing more.
    With Michelin, we have run the EVO DOT's to almost bald with no considerable drop in laptime. Again - it goes back to the chemical make-up. When the compound has stopped working, the tire is done. and the laptimes show it.
    Now - if only people would stop with DOT dates....
    Check out my eBay store!
    Dave - Motorace - Michelin
  18. #68
    Jan 2012
    OK
    i was able to get rid of the F3 and got a 2016 gsx-r750.. it has BT-016 on it factory.. but i think i should just take them off and go pirelli ..
    im gonna be on street and track but prefer track and hopefully spend more time there . in the near future i may just go all trackday..
    that said, can i get away with the Pirelli Diablo SuperCorsa SC V2 ??
    You might be able to, but I'd go with the Rosso Corsa. Really is a great tire for both. About to throw a set on the zx in the next few days.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Aren't rosso corsa the street tires? And if he's going to steer towards doing mostly track days wouldn't the supercorsa v2 make more sense?
  21. #71
    Jan 2012
    I'd like to go SC V2 if they would warm up on the street after some normal riding and would be safe
    Hiram, ME
    If your bias(not just percentage done, but desire to be applicable to) is towards track, the Supercorsa will be fine. You'll find most of Tony's staff runs them, with no warmers, at trackdays. I've got them on my street bike. While some common sense is required to let them warm up if you're gonna ride hard on the street...that's true even of dedicated street tires.
    Jul 2014
    Central CT
    Ah, you want the option to ride street. I've no idea how the supercorsa behaves as a street tire. But the street tire is probably equally good on the track. I'm thinking out loud here. Trying to figure out christians reasoning.
  24. #74
    Hiram, ME
    All that said, they will wear out faster on the road than Rosso Corsas would. Meaning you can't expect to get thousands and thousands of highway miles out of the center of the tread, like any road tire will give you.
    Jan 2012
    Awesome thanks !!!!
  1. For Sale - Other | free fitty free - Pirellis
    By cdovego in forum For Sale
    Last Post: 04-26-16, 04:36 PM
  2. New Pirellis installed! k6 750
    By SPGixxer06 in forum Bike Maintenance
    Last Post: 07-03-09, 09:39 AM
