This is a total dumbass question.. but I need help. My headlight went out ('02 zx6r ) and where there's only a low beam on one side, I forget which freakin side it is.
Also, do you guys recommend any aftermarket lights or should I just go with the generic replacement?
Thanks and I apologize for cluttering the board with a nimrod request.
thanks...
Do you have an owners manual? Should say in that.
Looks like your lowbeam is on the right if you are facing the headlight. Not 100% sure.
i dont have a manual, but i think i've hunted down the pdf online before. i'll try that.
course all my lazy ass would have to do is switch out each bulb and see for myself... but i AM lazy.... well, somewhat.
thanks for the advice.
hey, dedham... too funny.. i grew up in norwood
thanks maing
Buy the pair of silverstars. They are cheaper in the pair and you will need it at SOME point.
2006 Ducati Monster S2R800
If you only have a low beam on one side then someone changed it from stock. It should have 2 low beams/2 high beams.
Get the regular halogen lights if you do any night riding. Those white bulbs SUCK at night, especially if the road is wet.
If your talking about getting a packaged pair, you not getting motorcycle silverstar,
the ones that come packages as a pair have a beam designed for a cage reflector, bulbs for motorcycle beams are different and only come packaged as singles
thanks guys... can recall the name right now, but i got what i needed..... some ultra white, xeon.. bright as all get out. bulb is tinted blue. lookin freakin sweet!
On my 12R which should have nearly identical headlights as the 6R, I couldn't see any difference between the "motorcycle" bulb and the twin pack so now I save a full $0.50 per bulb by buying a pair!Originally posted by RandyO
Not sure which bulbs you used but the Silverstars have been very good during wet night rides.Originally posted by SWEET_Z
Get the regular halogen lights if you do any night riding. Those white bulbs SUCK at night, especially if the road is wet.![]()
