Results 1 to 18 of 18
Turn 2
    LRRS CCS AM#636 blacklightning's Avatar
    Goffstown, NH
    Turn 2
    Just curious. Did anyone else hit their shoulder on the red/orange air barrier in the new turn 2.
    I have heard of one other besides myself.
    LRRS/CCS AM 636
    Re: Turn 2
    No, but that was a tight exit for sure.....
    Re: Turn 2
    Is it a different turn yet? What's the new layout like?
    Nov 2007
    Re: Turn 2
    Fresh pavement on the inside of the old pavement... it seems to have good grip but there is a definite bump onto and off of it that felt a little hairy for sure. I found myself taking the old line a lot of the time.
    Basically the curbing/line moved in a couple feet. They only marked it with tape for the races and put in the airfences to stop people from going inside the tape... they are looking at a removable curbing for permanence.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: Turn 2
    not much different at all, just curbless.
    instead of a concave bermuda traingle, it's a much bigger convex triangle... mentally the best line is about 18"-2 ft in from the tip of the triangle (closest to nascar wall), the fast guys seemed to be going tighter, where the "hump" was bigger. I saw the turn for the first time in a race, and only 8 times after that... but that was my take.
    Nov 2003
    New Milford, CT.
    Re: Turn 2
    Very similiar feeling in how you eventually end up coming back out onto the back straight. Trying to cut it tight, even on the SV, did evoke some serious leaned all the way over wheelie/rear slide combination carnival fun ride. But my line has always been very direct out to the wall, good or bad. The turn seems to be moved "back and to the right" a little so exiting 1A you have to finish the turn a little more.
    Over all not much difference.
    CCS LRRS #454
    Posting Freak Gecko's Avatar
    Jul 2008
    Re: Turn 2
    Red/orange air barrier? I thought it was blue ... and yes, I plowed my head and left shoulder right into the first air barrier hard in F40 on Saturday. Why they put the barrier right on the edge of the turn is beyond me. I noticed they moved it back away from the corner for Sunday's practices and races.
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
    Re: Turn 2
    not this guy <
    Goffstown, NH
    Re: Turn 2
    Quote Originally Posted by Gecko View Post
    Yeah, the first one was blue, the middle/second one was red, right at the apex.
    LRRS/CCS AM 636
    Re: Turn 2
    Quote Originally Posted by zx1012r View Post
    Hmmm... I've always been a huge proponent of finishing 1a before heading for the apex of 2. It requires a quick turn in, but allows the drive out of T2 to start well before the apex and doesn't require that extra turning I see so many people try up on the banking at WOT.
    Lake Champlain, VT
    Re: Turn 2
    sounds like my line that was working! I was outdriving lots of bikes coming out of 2 with this method, a few people using me as a carrot caught on... The pucker potential went up in the cones for T3 braking though if and when you go in side by side with somebody coming in from the wall.
    Re: Turn 2
    It's great for both passing and clean hot laps IMHO.
    Nov 2003
    New Milford, CT.
    Re: Turn 2
    Yeah, I wouldn't suggest my line on a big bike!
    I'm not heading right at the wall, but am making a long arching turn at WOT through there. Definately wider than a lot of people.
    My absolute strongest corner at Loudon is turn 1. I can go pretty fast through there ;-) But I sacrifice some of it in my line through 1A and therefore 2. The front absolutely plows through 1A and therefore I can't seem to finish the corner. Obviously this could be changed by slowing through 1 slightly. But it is sooooo much fun attacking people coming in there it's like a drug I can't stop taking. It's the one part of the track I can claim as my own most of the time.
    I need a 12 step program.
    1. Finish turn 1A
    2. Turn in to 2 with a shallower tragectory
    3. Get on throttle way before apex
    Just have to figure this out without losing my fun time in 1!
    CCS LRRS #454
    Re: Turn 2
    I backed out a click of rebound on the rear to handle the transitions. + The closer you could get to the air fence the better.
    Re: Turn 2
    Mark, I agree attacking in 1 is great, but I think there's time in T2. I was pretty fast through there in my day, and I still used the wider setup. Finishing 1 better might be the answer. I find the new section does not flow like it used to... which is a bummer on a small bike.
    Nov 2003
    New Milford, CT.
    Re: Turn 2
    Yeah, Paul, When I follow Ricky through 2 he is way down in the middle of the track shooting toward 3. That's kind of how I figured out I wasn't getting turned in 1A enough. His line isn't that much different through 1A, but he is a lot more confident on the side of the tire at WOT exiting 2. (Same kinda thing through 10, I go way wide, he stays tight) I got a little lazy riding the EX500 being able to whack the throttle earlier through 2 and it has translated to the SV, but the SV is harder to keep turning under throttle.
    I usually (other than this weekend) spend my time on the track chasing (running a production bike in non production classes) so I get used to catching people on the brakes, but I will have to try adjusting and see if I can use the best of both techniques!
    I gotta do a few trackdays with you, I bet that would be a blast!
    Mark.
    CCS LRRS #454
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    Re: Turn 2
    Mark.
    We'd love to have you Mark!
    Lifer CMG241's Avatar
    Windham, NH
    Re: Turn 2
    I CW'd both days and by late Sat the bags were inching close to the white line from the hi wind, not so bad on Sunday. Personally I would rather see them further off the line if I were racing. you could always see Eric early the next sat and make suggestion.
    oh and it was almost amusing watching riders trying to figure out the pit out..
  1. How was the turn out?
    By Speed Demon 828 in forum Pit Area
    Last Post: 05-17-11, 09:30 AM
  2. will not turn over
    By robertmichaels in forum Bike Maintenance
    Last Post: 08-31-10, 06:30 PM
  3. NHMS Turn by Turn Journal
    By CEO in forum Pit Area
    Last Post: 08-28-08, 11:54 AM
  4. How do you think this is going to turn out?
    By LuvDog in forum General Bike Related
    Last Post: 06-05-06, 11:30 AM
