Results 1 to 25 of 27
Drilling bolts- how many holes?
    Windham NH
    It just took me a good 10 minutes and 2 bits to get through my drain plug head once. Is there an advantage to drilling through all 6 faces of the bolt head or can I just do one and done?
    Large member Larry's Avatar
    Nov 2010
    Limington maine
    Re: Drilling bolts- how many holes?
    Try marking the bolts in place and remove/ drill one at a time. Be sure to use cutting fluid or oil and clean chips out of the drill flutes often to prevent galling.
    Are you drilling through the entire head or just two adjacent flats? Yes it's an ass ache, but no need to make it even more difficult.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Drill what is necessary to sufficiently secure the bolt. Sometimes that means "directly" through. Sometimes that means through 4 faces (which means 2 corners) if you are wiring something with a stud.
    Generally if you have a head that you are securing a "straight" through works.
    If you have specific questions post a pic. There are plenty of critics here.
    Windham NH
    I went straight through the whole bolt head. I think it will work. Probably should have just gone two adjacent faces.
    Uhhh yeah... Don't go through the entire head, just drill at an angle and use a center punch if you need it to keep the bit from walking.
    Torque the bolt, mark the side(s) you want to drill, remove & have at it.... and buy a ton of bits.
    thrilled brady's Avatar
    Nov 2007
    Raymond, NH
    I've dished the head of larger bolts with a large bit, then drilled straight in from the sides, ends up looking a little like the Probolts and saves a bunch of drilling with the small bits.
    I need to start doing this on my minis
    can't you just do this?
    That's what I've always done.
    Yes
    And the angle is why you need a center punch. Otherwise you're puting a lot of side load on the bits trying to keep them from walking sideways.
    Jan 2012
    if u dont have a punch.. u can start a tiny hole straight.. just a lil bit and then turn it to an angle.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by caloots View Post
    exactly what I was going to suggest. center punch first cause it'll still want to walk then go in a little straight then go at the angle. works great.
    and don't put too much pressure behind the drill. that's when bits break. I think the best bits I've found are Dewalt, I forget the metal. might have been titanium.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    I am more of a fan of drilling all the way through.. It is a bit more work. Especially if you don't have a drill press and a vise.
    Bits..... Go in a horses mouth..
    Drills go in a drill chuck to cut metal.
    Titanium is used to make light strong parts. (consumer advertising is stupid).
    Titanium Nitride is used to coat a steel or carbide cutting tool to make the surface of the tool harder and more heat resistant...
    The best drills for safety wire purposes are ones made from cobalt and with a 135° split point. Real cutting oil will make it go a lot better too. You need plenty of RPM for a 1/16" drill to cut well.
    Side pressure is the enemy. So is break out on the far side. When you start breaking out you need to ease up on the pressure.
    Sorry
    AM #152 tropicoz's Avatar
    Apr 2010
    Maine
    Agreed on the cobalt. Little more expensive but much more durable.
    Sorry
    Any sources for purchase of these pure cobalt drills for the non-machinists among us? Best I can find are alloys of 8% cobalt
    Last edited by carsick; 04-21-14 at 10:06 PM. Reason: questioning elemental purity
    Sep 2010
    Granville, NY
    Added to cart...
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    I've gotten my latest 135 degree bits at Fastenal.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Nov 2007
    Raymond, NH
    any good reason to use 1/16" instead of 5/64"?
    Jan 2012
    ya, I have a set of dewalt.. i cant remember.. i think it is titanium.. they are gold.. they work excellent !!!
    Senior Member MarkMarine's Avatar
    May 2013
    Yeah if you want to piss money away. Fancy bolts should not be part of a racing budget.
    Bridgewater, MA
    those are the ones I use too.
    Quote Originally Posted by MarkMarine View Post
    they are if you want to feel like a MotoGP team.
    May 2013
    Right. And have motogp sized budget. 8$ per bolt, that is pure insanity.
  1. Replies: 23
    Last Post: 10-20-14, 09:01 PM
  2. How do i fill these holes?
    By R7 in forum Pit Area
    Last Post: 07-24-04, 08:32 AM
