Results 1 to 21 of 21
5/14-15 LRRS Race Weekend
    Red face 5/14-15 LRRS Race Weekend
    Well lets start by saying who's going?
    I tried the 1500# in NJ and had experienced a little hot/Spring tear. It is an old tire and this is typically what happens when I get to the end of its life. I was also running it at 27psi. I'm going to up it to 28-29 psi to see if it heals itself in the upcoming practice sessions.
    In prepping the bike I swapped out the 17t sprocket back to the 16t.
    Did an oil change and flushed a quart of oil thru the engine before I noticed the oil pan filling up did not put the drain plug in. Button everything up. Crank over the engine to circulate the oil into the engine. Everything topped off and working ok.
    Figured it has been a while (1 Year) since I went thru the carbs. 1st thing I noticed was the plastic retainer was not locked into place. One of the clips on the needle was not in the middle. It looks like it worked its way onto a lower seat and marred up things a little. Everything else looked OK. I had to readjust the rear float bowl height. That was major surgery
    I worked on trying to straighten the sub frame with a dead blow while connected to the bike. It worked this (ll) much. I did not want to go too hard to break anything in the frame.
    I put the tank on and start to get the tail on. I check all connections and begin to prime up the bowls. nothing. I go to crank over the motor. Nothing Tear the tank off and begin metering things.
    Battery is a little weak 9-10volts. That should turn over the Fuel pump. I have power all over my connections. (Race harness easy to follow) Why does the Fuel pump not work now? The two fuses look good. I know the battery is 6-7 years old and has survived many dead cycles. Lets swap it out with the CBR. Things crank up. Still wondering in my mind, this was fine 1 hour ago,why is this completely dead. It's been trickle charging the entire time. Something is up. I connect the fuel pump to see if that works. Nothing. I check the starter. Nothing I check the fuse from the bat. TOAST. Put a new one in. I unplug the FP and the starter works. Plug in the FP. Fuse is TOAST. I meeter the FP and it appears to have continuity thru it. Hhhhmmmm
    I jump the FP straight to the Bat and things arc out. WTF. That is not right. I tear the back of the FP open and check things out. It all seems fine except for the spring. It does not appear to be sitting right. I begin wondering. With the hammering to the sub frame did the spring dislodge and jam things up. With the pump not being able to operate correctly did the FP just load itself up and cook something internally? Possibly. I fixed the seating of the spring and things seem to operate correctly with me puling on things. I direct connect to the battery and is still arcing out. Something internal has got to be toast. Looks like I'll be using my back up pump. As well as looking for a new one.
    Needless to say I did not get things packed up last night. Looks like I'll be tiding things up tonight and heading up Saturday in the early AM.
    Re: 5/14-15 LRRS Race Weekend
    Hope ya get it sorted, bro!
    I'm gonna try n get out of work a little early, head home, pack up and head on up. Might be bringin an umbrella girl, too
    I still need to change the oil in the turd, and cross my fingers I don't find a bunch of metal in the screen. Pending that, I'll be up Saturday evening. I'll be in a great mood, not caring about championships, paintjobs, trophies, or bumping, so say hi. And if I butthurt anyone with this weeks innerwebbing, we can hug it out.
    I can't wait to
    ... with my umbrella girl
    Don't be
    Lifer Pittenger5's Avatar
    Austin
    I bet Petes "umbrella girl" has a fuller goatee than him
    Zip Tie Alley #505
    Rocky Hill, CT
    Need to change the oil in her but other than that and some packing I am ready to go. I should be rolling into the gates around 9pm tonight.
    LRRS CCS AM#636 blacklightning's Avatar
    Goffstown, NH
    So................ this....................really?
    LRRS/CCS AM 636
    DON'T FORGET TO CHARGE YOUR TRANSPONDERS!
    I"m good to go. I was going to have Michael come over and see if he cold help with the squishy brake lever I seem to be having, but I bled it a little this morning and it seems to be better than it was. I didn't see any bubbles come out, so maybe I was just being a little paranoid, as usual.
    This will be the last round I'm using the 2 piston calipers on anyway. (hopefully)
    Lifer smf's Avatar
    Nov 2006
    I can't wait to
    gonna miss the love-in
    btw gino. i've got a spare electric fuel pump or 2 if u get jammed up... and maybe you should switch over to the vacuum pump. no power needed!
    Scott
    Member kellis159's Avatar
    Apr 2011
    Middleton
    Talking Re: 5/14-15 LRRS Race Weekend
    Don't be
    Peeetttte!!! Umbrella girl, eh? hehehe... does she pack Oreos? Hope to see you there...
    Just the right amount of wrong... hehehe...
    Quote Originally Posted by kellis159 View Post
    That's a bit cheeky to ask in public isn't it?
    pm sent
    PS, the goat is a bear(d) now.
    Quote Originally Posted by smf View Post
    Thanks. I'm going to be using my spare. I'll be looking to replace it if you want to let one go. Ask Bill how his new vacuum pump worked out?
    creamy filling
    or the other way around, maybe?
    Lifer smf's Avatar
    Nov 2006
    been working fine on all mstone builds for years now, mine included
    i've got at least 1 pump. i think 2. i'll trade ya for some trans gears
    Scott
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    Gonna be in town for a wedding tomorrow, so I'm planning on heading up on Sunday. Looking forward to seeing some old friends
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Quote Originally Posted by Puppet View Post
    AWESOME!
    In the South garage to the West end. Next to Pirelli.
    It looks like a drive up race and drive back day for me.
    Just scored some B's playoff tickets. Center ice
    I'm going to be one tired pup.
  1. Replies: 26
    Last Post: 09-05-14, 11:27 PM
  2. LRRS AM 516 Classic Weekend Race Report
    By Palm Bomb in forum Pit Area
    Last Post: 06-23-11, 05:44 PM
  3. RSP # 816 race report - LRRS weekend 2
    By Mr. Kurtz in forum Race Reports
    Last Post: 05-17-10, 07:03 PM
  4. Race Weekend #6 - LRRS 4/24/10
    By daviid in forum Race Reports
    Last Post: 04-27-10, 07:52 AM
  5. LRRS WEEKEND
    By trackdog in forum Rides & Events
    Last Post: 09-23-03, 10:24 PM
