Results 1 to 9 of 9
65mm axial caliper
    Senior Member Dannyf's Avatar
    Middleboro, MA
    65mm axial caliper
    Wondering if anybody has some axial mount calipers lying around. Looking to throw one on my motard while I save up some cash for a Beringer setup. Just has to be left side with 65mm center to center mounting (mid 90's to early 2000's sportbike) looking to spend about 50-60 bucks.
    Thanks,
    Dan
    "When there's a gap you either commit yourself as a professional racing driver that is designed to win races or you come second or you come third or come fifth, and I'm not designed to come third, fourth, or fifth. I race to win, and if you no longer go for a gap that exists, you're no longer a racing driver."
    Ayrton Senna
    Re: 65mm axial caliper
    What are you using for a m/c?
    Middleboro, MA
    im going to see how my factory 450 MC feels. IK a streetbike one pushing a single caliper will be way to stiff but the KX is really stiff with the stock 2 piston so im hoping going to a 4 piston softens it up and gives it some feel.
    Ayrton Senna
    Haverhill, MA
    Don't forget that some calipers from normal street bikes may not clear the spokes on a motard that well. I know my Brembo has a different back half of the caliper body to prevent it from rubbing the spokes.
    One of the asphalt flat track guys at Loudon last race weekend had an interesting ride into the tire wall because his spokes had rubbed through the back of the caliper and when he grabbed the front brake heading into turn 1 he had nothing. That had to have been a scary feeling.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Are you thinking just because the mounts are 65mm apart, it will fit your wheel/rotor?
    I think you should be prepared to have a custom bracket made at the least... What size Rotor are you using? Joel speaks truth, but depending on caliper, you could always machine down interfering parts with a mill.
    I am going to try and FAB a bracket for an R6 caliper on a YZ450 w/ 320mm rotor.
    Middleboro, MA
    I'm fully aware that I may have clearance issues and will need to fab up a bracket. I'm running a 320 rotor. I was hoping to find a r6 caliber as they are thinnest although I'm sure a gsxr or cbr caliber will fit with a small amount of milling to caliper.
    Ayrton Senna
    Bullshit meter pegged scottfromboston's Avatar
    Oct 2009
    Maynard,MA
    When I was looking around at better calipers for my DRZ, I found someone that had fabbed up a pretty slick solution for a radial mount sportbike caliper using only angle iron, grinding, drilling, and hardware.
    I'll see if I can dig the Thumpertalk thread up.
    ~Scott
    2020 SMC-R
    Oct 2009
    Maynard,MA
    Quote Originally Posted by scottfromboston View Post
    http://www.thumpertalk.com/forum/sho...54&postcount=4
    ~Scott
    2020 SMC-R
    Lake Champlain, VT
    Quote Originally Posted by Dannyf View Post
    If you're going to fab a bracket, why does it matter if it's 65mm or 40mm?
    Also, I don't think yamaha R6 ever came with axial 4 piston calipers.
    Is it axial or radial you're looking for?
    With that said, you should find axial mount calipers are fairly inexpensive on ebay.
  1. For Sale - Gear | Dainese Axial D1
    By SwiftTone in forum For Sale
    Last Post: 09-22-20, 02:29 PM
  2. For Sale - Gear | Dainese Axial Pro In
    Last Post: 01-04-20, 09:33 AM
  3. For Sale - Gear | Dainese Axial Pro IN Sz43
    By MotoFreak in forum For Sale
    Last Post: 06-08-19, 12:28 AM
  4. Dainese axial pro boots??
    By boloson in forum General Bike Related
    Last Post: 10-07-13, 03:44 PM
  5. Caliper issues
    By jewfzr in forum Bike Maintenance
    Last Post: 09-14-10, 11:55 AM
