Results 1 to 8 of 8
Best adhesive for securing eject system - or is it toast?
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    I retired a helmet this past weekend, and retrieved the (1 day old) eject system from it, which was not deployed (has one ever been deployed at Loudon?)
    It was still sticky, but like a dumbass I stuck it to a plastic bag for "safekeeping", but the adhesive was so good that the bag is still stuck to it and the little attached square pulled off.
    So while I totally buy into the "don't mess with important safety gear" philosophy, I'm also thinking that all i need is something to keep the bag in place unless and until it's needed - with the caveat that I have to be absolutely sure that it won't eat into the foam shell of the next helmet.
    Does anybody have any knowledge in this arena, or am I just out an extra $70 bucks just to be on the safe side? Don't mind paying that, but if there's a way to safely attach it to the next hemet I'd rather not trash it.
    LRRS 919
    Re: Best adhesive for securing eject system - or is it toast?
    Two side tape? Ducttape? Glue?
    Sep 2013
    Ok, cool. Just wanted to make sure it wasn't one of those holy grails that nobody messes around with.
    My general feel is that people view them as more of a PITA than an actual useful safety device...
    LRRS 919
    Most will probably advice you to get a new one. Iv moved mine to 3 helmets total no problem
    Lifer Stromper's Avatar
    Eastern Ct
    Foam mounting tape
    2 sides with foam in between allows surface to mold for proper contact
    As best as possible clean surfaces if on EPS then MAYBE like alcohol would be good (test first)
    MOST solvents will dissove EPS INSTANTLY
    The calculus of hate
    Best way to stick that thing?
    Straight into the garbage.
    it doesnt work anyways, so just stuff it under the padding of the crown.
    double sided ape from 3m should work though
    Senior Member MarkMarine's Avatar
    May 2013
    Just unstick the tape that it's stuck in with and put it in your new helmet. Don't buy a new one.
    Honestly, it's like LRRS got some kickback or something from the manufacturer. They make one that the EMT can keep and just slide in the helmet if needed, but instead they made us all buy them. BS.
  1. Eject System
    By "Dangerous" Dan K in forum Pit Area
    Last Post: 04-02-14, 12:36 PM
  2. Replies: 61
    Last Post: 10-29-13, 02:27 PM
  3. Replies: 1
    Last Post: 03-17-13, 02:49 PM
  4. helmet eject system
    By vintage ex race in forum Pit Area
    Last Post: 08-04-12, 05:29 PM
