Results 1 to 10 of 10
New brake pads
    Lifer Fitz's Avatar
    New Boston, NH
    New brake pads
    Putting the second TLR caliper back on the front of the SV this weekend. As recommended, I ordered a fresh set of EBC HH pads from Souhegan Valley Motorsports. Ridiculously quick turnaround.
    The question I have is I used to use 120 grit sandpaper to clean up the rotors on the race car before mounting new pads... Is this a decent enough grit for brake rotors? Too rough?
    Thanks!
    Fitz
    Re: New brake pads
    I use a green scrubbie mounted in a drill fixture...
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Re: New brake pads
    I mount the pads, do a quick ride around the paddock dragging and stomping on the brakes, then go.
    Boston --> San Diego
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: New brake pads
    I test them in T3.
    Meriden, Ct
    Re: New brake pads
    120 grit? Jesus no. Don't put that anywhere near your rotors. If you want to clean your rotors up... Use some Scotch Brite and break cleaner.
    Lifer union's Avatar
    Blackstone, MA
    Re: New brake pads
    +1
    James
    Re: New brake pads
    Drag your front brakes around the pit til the front locks up and spits you off.
    Lifer Evil_Weasel's Avatar
    Over the Highside
    Re: New brake pads
    As usual, your post displays a complete lacking in any fucking idea what you're talking about.
    Hey, at least you're consistent.
    Lifer Fitz's Avatar
    New Boston, NH
    Re: New brake pads
    All buttoned up. I miss the limited travel of the lever with one brake caliper but it should provide some extra heat capacity. Going to warm them today and then bleed again via vacuum pump.
    Thanks!
    Fitz
    Re: New brake pads
    Get a bigger master, tada less travel! : )
  1. Brake pads
    By Garandman in forum General Track Day Talk
    Last Post: 07-29-19, 07:15 PM
  2. New EBC Brake pads FA 322/4HH
    By 03Worc9R in forum For Sale
    Last Post: 07-04-12, 05:41 PM
  3. need new brake pads
    By DaveZX6r in forum Bike Maintenance
    Last Post: 03-09-12, 01:19 PM
  4. Brake Pads
    By chris275275 in forum Bike Maintenance
    Last Post: 02-25-12, 12:59 AM
  5. New Brake Rotors = New Brake Pads?
    By highsider in forum Bike Maintenance
    Last Post: 03-27-07, 10:39 AM
