No ur wrong its Hp.....If he did that he would be shifting at 11K. Bike still makes power up to 15-15.5ish
If it was a LS6 BB chevy thats a differnt story as cars to bikes is.....Torgue isn't like in a car the HP is what does the real work
Just look at this dyno sheet as an Example: you would be shifting at 7K if that was the case
LRRS EX 66
factoryeffex
Based on that torque curve I wouldn't shift at 7k, even without knowing the gearing I'm going to be going back to a point with less torque shifting that early. 9k looks like a better candidate, maybe pushing past a touch if the gearbox would make you dip past 6k when you grab the next gear. That'll keep you in the meat of the torque, but you've got lots of overrev for when you need to skip a shift due to track layout. (Ok, we're talking about a Busa so it's all straight lines but still...)
Rev to Peak HP and shift easy as that.......
LRRS EX 66
factoryeffex
If you're that anal & wanna get crazy with it.... http://www.sportrider.com/tech/146_0402_art/
You've only got a USB cable for that right, not a standard serial cable?
No, changing sprockets would alter the MPH you'd be at when you shift, but not the RPM.
According to that article, my GUESS is yes, but barely. Changing the final drive ratio would affect all gears "equally", but because it's by a percentage it may change it a little. You'd have to do the math.
LRRS Am #331
LRRS EX 66
factoryeffex
15k RPM on a chinese crank, rod and cast piston. Shouldn't even have run it up that high but it just kept making power so... If I had a spare bottom end I would have finished it off on the dyno just to see where it'd let go, but it lives on now as a tractor in Doc's 70.
LRRS Am #331
where is the 169MPH GPS identified you said you hit?![]()
I'm not sure what's being argued here...
But: Jim is wrong (and fat), Piggy is right, Pete is handsome, and Josh is spouting loads of crap that's over everyone's head.
when you say +1 you're talking about the front sprocket right? for some reason it sounds like you're talking about the rear but that would give lower top speed
LRRS Am #331
