Results 1 to 6 of 6
Clutch plate install question
    I realized while looking at my old clutch (after I buttoned everything back up) that the steels have a very flat side and a slightly more rounded side to them, caused presumably by the stamping of the plates.
    Are they directional?
    Re: Clutch plate install question
    I don't THINK so.
    Me neither but I figured I'd ask to be sure.
    No.
    Lifer Stromper's Avatar
    Eastern Ct
    If I have a clutch apart I dress all sharp edges
    I would think the stack would move IN easier under spring pressure
    If the radius was in the IN direction
    But I doubt it matters
    The calculus of hate
    You want all the sharps going in the same direction. Either all sharp edges in, or sharp edges out. No need to dress them, etc, just be consistent in how you stack them. Now, as to the why: If you don't stack them consistently you end up with a fiber that's between two rounded faces, meaning it sees less steel surface area than the other fibers, and vise versa one fiber will see more due to having both stamping edges against it. Net result is under duress that fiber between two rounded edges will give sooner, and your stack will slip and wear sooner than it should. This is coming from the drag racing world but I'd consider any slipper setup just as stressed.
  1. Install a Magura Hydraulic clutch on a wr250f
    By black in forum Dirty Bastards
    Last Post: 04-09-22, 06:05 PM
  2. Slipper clutch install-- SV650
    By Charlief in forum Bike Maintenance
    Last Post: 09-09-10, 01:16 PM
  3. Clutch Pressure Plate Shattered
    By Manny in forum Bike Maintenance
    Last Post: 08-07-09, 01:18 PM
  4. clutch pressure plate tool
    By Truth in forum Bike Maintenance
    Last Post: 09-30-08, 03:16 PM
  5. replacing clutch plate
    Last Post: 07-05-08, 06:53 AM
