I am trying to convert all of the bodywork mounting points of my SV to be dzus fasteners. But I've come across an issue with the mounting brackets on the upper.
The brackets are 1/8" thick and the fastener pin cannot grab the wire on the inside due to the added thickness.
I looked to see if they made longer pins, but it doesn't look that way.
Any suggestions?
FYI Woodcraft sells there own dzus and they are about half the price.
Duncanmoto has some in stock, not sure if he has the correct length for you application?
Thin down the bracket with a grinder perhaps?
Good call, Jim. The Ducati seem to be a little longer than the ones I bought.
The ones I picked up are 12-13mm in from the inside of the screw head to the tip of the bolt. The Ducati are 17mm. These may do the trick, and they're longer.
Might shoot Ted a PM to see if he has any.
Zip ties,
Because in a crash I have found that the Zip ties stretch and break, Absorbing some of the force then the upper will flex a bit The trick is not to have the zip ties too tight or too loose. If you put fasteners on it it will be prettier but even a simple drop will have you replacing fairing stay ears and dicking with fiberglass the next week. everything gets so tight the fiberglass will break.
Zip Tie Alley Racing #444
Signature edit by Tricky mike
Have Noel order them for you.
http://www.powersportrider.com/CGI-B...page=244%20.00
R.I.P. - Reed - 3-23-2008
It's not called zip tie alley for nothin.
