You can get a 3 digit number on plates like this. All rolled through tech no problem. They usually bust my balls over stupid shit.
Peach Pit paint job
Rattle can
Landrics plates. Also go through tech no problem. They are the biggest ones out of the three so the numbers fit a little better.
Also keep in mind that experts get away with a LOT more with regard to things like that than a novice, especially a rookie. Your first weekend tech is probably the most intense scrutiny your bike will ever get.
-Brian
15 S-Works Venge
They whisked me through no-prob...And I did all the classic novice shit like leave helmets and reg forms back yonder. I say go for it, and if there's a problem come find me. I'll likely have a extra sheet or 2 of white background and we'll make that bike ugly.
75 Days
Goals? Not be last at the beginning of the season and at the end of the season not being lapped. And have fun. Cannot wait to see everyone again.
74 days cant wait to see everyone eaither
72 Days![]()
This is seriously the worst thread ever. Cut the shit, man!
I see this thread every time you post in it and you're making winter feel like a fucking eternity.
Forget about the # plates, those are easy enough to redo, but what about the routing of vent hoses? I just moved mine so they dump into the lower of the fairing under the exhaust. Is that what is usually done on a stocker like mine? Anything need to be done with the crankcase breather hose?
LRRS am #121
here's a link to the rulebook...
http://www.lrrsracing.com/2010/2010_LRRS_RULES.pdf
all that crap is supposed to go into 750ml catch cans, if i'm not mistaken. i don't think the belly pan was intended for that, really. will you get away with it? maybe. the only thing i can guarantee from tech is they will look at your helmet, and test your fuel if you either: win or do something dumb. like stop for lunch at the 3-10 split.
also, since it's a ccs rulebook, try the ccs forums or wera on bike setup. i'm moturded, so i'm not too much help here.
Thanks Chip, I'm pretty familiar w/the rule book, but the catch can stuff doesn't make much sense to me since there really is no place to put them! The vent hoses on my bike run down the sides of the engine down by the foot pegs and the only place to put a 750ml catch can would be the battery box but then the hoses would be running upward and wouldn't drain at all. I thought I heard somewhere that those just go into the "oil catch pan" i.e. lower fairing. Just wanted to make sure.
LRRS am #121
Zip-Tie Alley Racing
LRRS/CCS #103
LRRS am #121
All this talk about the rulebook got me all excited; I thought the 2011 book was released... yeah..... no. Oh well.
Fitz
Another country heard from on this one..........................
One other thing to consider is riding/racing in the rain. I have seen in the past that the lower on some fully faired bikes have some rubber plugs in them such that when it is raining they can be pulled so that rain water doesn't build up in the belly pan during racing and then slosh out in front of your rear tire causing traction issues. I have no idea if this is fully rule book legal but I have definitely seen it done this way. So if you have this situation you would be much better off having a catch can so as to prevent these slippery fluids from draining out in front of your rear tire and causing the aforementioned traction issues.
Joel
Just a personal thought, but I would be doing whatever I could to avoid dropping fluids on the track. Not only to limit the chances of causing yourself to crash, but also to avoid being "that guy" who drops oil on the track causing a multi bike pileup and/or a long delay for fluid cleanup. Its easy enough to run the vents into a plastic bottle ziptied somewhere out of the way.
-Brian
15 S-Works Venge
