Results 1 to 25 of 27
What size generator do we need?
    Just Registered Doc's Avatar
    Jericho, VT
    For the infield?
    I run tire warmers, helmet drying fan, trickle charger, radio (for race calls) and a Fridge at the most during the day. (could do without the fridge I suppose).
    What do you guys need power for?
    2000 watts work? Bigger? Smaller?
    Discuss.
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    Re: What size generator do we need?
    warmers are generally 1000 to 1300 watts a set
    -Benjamin Franklin
    You could do without the fridge "you suppose"? Holy shit man! Where does it end?
    You could do without everything but your tire warmers.
    I gots me a 5500/8500 peak that I could rent out for the weekend
    Jericho, VT
    Small battery in the bike, needs the charger.
    I sweat like a pig and need the fan.
    You want cold Guiness.... I need the Fridge.
    Lifer Pittenger5's Avatar
    Austin
    The man needs the fridge.
    Zip Tie Alley #505
    After bringing a fridge to the last few events last year, I absolutely will not go without.
    Nancys, the lot.
    Member tdiloren's Avatar
    Oct 2008
    Maine
    Will electricity still be an issue for the May 26 & 27 TTD. I have a 5000w generator I can bring.
    AMA wannabe lrrs699's Avatar
    RI,NH, Derby,ct
    For the infield?
    Discuss.
    Bring a big one and camp next to me, i will save you a spot...especially if the rumor is true..
    LRRS Expert #99
    08 R6
    "why tip-toe through life to arrive safely at death?" Tony Campol
    To quote PK, I "went in too hot and ran out of talent".
    live to ride seth399's Avatar
    Feb 2007
    CA
    a helmet cooling fan?? I didn't know those exist ehe
    LRRS #399
    MX #505
    Sep 2006
    Around the corner
    http://www.nestreetriders.com/forum/699332-post12.html
    add in whatever appliance you want just figure that they will all run at the same time and you should be all set.
    quantity over quality .... the type of stuff we need at the track does not need 'super clean' power ... just needs power. higher watt capacity = more racers with more stuff they are use to having. cold Guiness, radio, cooling fans (for bikes and racers), lights ............ back during the ice storm Home cheapO had 12,000 watt gen sets for $1200 1:10 is actually a good ratio when it comes to generators
    hope this helps DOC et al.
    The rule is:
    Jul 2005
    Bennington, NH
    So, Doc does this mean you're racing this coming weekend?
    Lifer Jayspeed's Avatar
    Medford, MA.
    For the infield?
    Discuss.
    Just look on any of these appliances you listed for a spec plate or sticker that will tell you the amps or watts it uses. If it provides amps( like it will say 2a) then multiply 120(volts) x the amps = watts. Now go count how many watts each unit is and add em up! It might also say Input Voltage- 120 V AC 60Hz 2a. Forget about the 60Hz just go for the V(volts) and A (amps). 120 x 2 = 240 watts. If it says the voltage and then the (W)watts then your all set, no arithmatic required.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Sep 2006
    Around the corner
    amps * voltage = watts
    1.5 * 120 = 180 watts per battery tender
    5 * 120 = 600 watts per tire warmer * 2 per bike = 1200 watts
    8 * 120 = 960 watts per air compressor
    14 * 120 = 1680 watts per a/c unit
    11 * 120 = 1320 watts per microwave oven
    these are some approximate numbers to consider when choosing a generator
    basically you'd be able to have two bikes with tire warmers and two battery tenders or a radio or something else small. if you wanted some other appliance to run you'd have to unplug your tire warmers to start the air compressor etc ...... etc ......
    The rule is:
    Jericho, VT
    Quote Originally Posted by seth505 View Post
    All the sweaty fast guys use them.
    Sep 2006
    Around the corner
    Fixed only cuz I'm a member
    All the sweaty fat guys use them.
    The rule is:
    Feb 2007
    CA
    ewwww!
    LRRS #399
    MX #505
    Jericho, VT
    Quote Originally Posted by The Crashing Tomato View Post
    Did I say fast? Frick I meant what you said!
    ewwww!
    Come give me a hug after the ULSB race. : I am furry too.
    Feb 2007
    CA
    something tells me I am not going to sleep well up at the track!
    LRRS #399
    MX #505
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    How much do I need? I have a electric drill, a Goerge Foreman grill, a charger for my cell phone, toaster oven, microwave, fridge, hair dryer, curling iron, slot cars, bud light sign, tire warmers, alarm clock, waffle iron, crock pot, pc, television, cable box, razor, toothbrush, sex toys, and some night lights.
    Feb 2007
    CA
    specify what size crock pot and if the sex toys are double ended
    LRRS #399
    MX #505
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    This just may be able to cover you,,,,maybe.
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
    Jericho, VT
    Nope. Just getting prepared in case I need it for round 3.
    Jericho, VT
    Where are YOU pitting. :
  1. Wanted - Parts & Tools | Looking to buy a used gas Generator
    By South of Heaven in forum Wanted
    Last Post: 08-11-14, 05:57 PM
  2. Replies: 6
    Last Post: 03-01-12, 10:48 AM
  3. Replies: 2
    Last Post: 09-02-11, 12:20 PM
  4. Replies: 29
    Last Post: 03-17-11, 02:43 PM
  5. Replies: 0
    Last Post: 05-08-10, 11:19 AM
