Page 2 of 18 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 437
Eject System
    Re: Helmet removal system?
    Too much noise over nothing! If it's required people will adapt to the new idea and rules and go along with it.. If not it will be forgotten..
    shut up pre-novice
    ridiculous
    Hiram, ME
    Has any official source actually said these are required for 2012?
    No and the final word comes down to what CCS says.
    We went thru this last year right around the same time for the same reason.
    Hiram, ME
    I guess LRRS could impose the rule even if CCS doesn't, but so far, it looks like the only indication is a notice from Rising Sun Cycles(who is selling them) on a self admitted unofficial LRRS website.
    Derry NH
    I think people are blowing this out of proportion. This will make it much easier for someone to get your helmet off without injuring your neck/spine. It's actually pretty ingenious. A little on the expensive side seeing you'll need one for each helmet and need to replace it every 2 years, but worth it if you ever truly need it.
    As for putting too much pressure on the skull, if your skull is broken/cracked through your helmet, you have worse things to worry about than a plastic bag assisting to get your helmet off.
    "Plymouth's Fastest" BrianC's Avatar
    Sep 2010
    Plymouth, MA
    Let's just hope they remember to undo the chinstrap before they start pumping...
    LRRS am #121
    Quote Originally Posted by BrianC View Post
    For someone that doesn't bother to carry any medical insurance, you sure don't have a whole lot of faith in the medical staff at the track
    Lifer FirstDuc-1098's Avatar
    Central Mass
    what about helmets that already have systems like this?
    Attachment 26969
    That is on the Shoei X-Twelve and others
    Would the Eject system work on this or would it interfer with it?
    Shit Corey says:
    Pete - He has a point.
    Quote Originally Posted by Eric Baker View Post
    You mean like irrepairable brain damage due to excessive applied pressure during a brain swell situation?
    The basis of my post was that introducing additional pressure to the skull is not where it's at as far as removing helmets. Cut the effing thing off if it's that serious.
    Cut it off? How the hell they going to do that?
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by MysteriousR1 View Post
    same type of saw they'd cut your skull open with. not too hard really.
    I think they would have to move your head around a bit to cut a helmet off..
    So do I
    I hear you, Pete, however I have that same concern in addition to many others as far as the requirement and necessity of this.
    BTW, what's up with Graham's post? Mandatory? Reason I ask is because I need to make a decision on how I will conduct my race program for 2012.
    Bridgewater, MA
    over the top of the head should make it pretty easy, pull the front half off and it should be easy to lift you up off the rest.
    Really? This is racing not knitting. Just buy it, show up, and race.
    who knows
    I would assume they would cut it off with a similar saw (rotory tool) that they use to cut off a cast? which if you think about it is probably the best way to remove the helmet if you have serious head trauma.
    I think there would be benifits to having the device in your helmet though... obviously in certain situations it might be better to use the device than pulling the neck but just becasue the thing is in the helmet doesn't mean that have to use it to take the helmet off 100% of the time.
    I totally agree that I wouldn't want thing thing putting un-neccesary pressure on my skull if I had brain swelling.
    I need to design a device that cuts off helmets safely if there isn't a way to do it all ready!
    ____________
    Also this shoei design is pretty sweet. I might have to go tray that helmet on and see how it fits!
    Attachment 26969
    Just Registered Doc's Avatar
    Jericho, VT
    Just wanted to chime it... Has anyone looked at the training it takes to use this system? Myself and 1 other EMT should be able to remove a helmet properly WITHOUT this system.
    How about installation? What if you put it in wrong?
    I just don't see the advantage.
    See some of the comments in this review. http://www.motorcycle-usa.com/396/51...al-System.aspx
  21. #46
    Tucson, AZ
    Just curious... do the medical staff at the track leave your helmet on until you get to the hospital or remove it? I'm just wondering what the odds that they have something to cut your helmet off are.
    Original
  22. #47
    If you are not breathing, the helmet is coming off at the track. No ifs, ands or buts.
    Airway is primary concern and trumps all others. Now, they are gonna be pretty careful taking it off and they have training in how to do it correctly but they aren't going to be taking 20 minutes over it if you have no airway and I'm pretty sure they aren't putting a hole in your throat either.
    I'm sure someone will confirm this.
    I can say at the moment that Boston Moto will not be requiring these devices until we have more information on them or NHMS makes it a requirement.
    I highly encourage that everyone read the comments in Doc's link.
    This is beyond just "buy one, show up and race". This system is introducing a larger margin of error on the part of the medical response team which puts you at a higher risk for injury and it's clear that many other people see this as well.
    What was formerly two people removing a helmet is now potentially 3 or more.
    Also, people, keep in mind that if this were to become mandatory, LRRS would be the ONLY place in the entire country that this system would be required.
    I went through the WERA rule book from cover to cover last night, in additon to the 2011 CCS rulebook. Not even a mention of installing these devices or even a recommendation.
    It does pose the question though, since no offical announcement has been made, is RSC trying to do nothing more that to generate sales in the offseason by putting up an unofficially "official" word? I mean, you guys do realize who owns RSC and operates the unoffical LRRS website, right?
    Please (!!) educate yourselves before making a blind jump onto the bandwagon.
  24. #49
    I would imagine that even with proper training, you're still pulling slightly on the neck because of the drag on your head/face/cheeks.
    I see the removal system as a helpful aid to quicken up the process, not a replacement for training.
  25. #50
    This thread has done something positive at least...I'm really thinking about getting the X12 now..
  1. Replies: 7
    Last Post: 08-05-14, 04:04 PM
  2. Replies: 61
    Last Post: 10-29-13, 02:27 PM
  3. Replies: 1
    Last Post: 03-17-13, 02:49 PM
  4. transponder and helmet eject thing
    By burnham in forum Pit Area
    Last Post: 09-02-12, 11:32 AM
  5. helmet eject system
    By vintage ex race in forum Pit Area
    Last Post: 08-04-12, 05:29 PM
