Results 1 to 20 of 20
Who has experience with throttle tube swaps?
    I was told that the R6 throttle tube changes the turn from a 1/4 turn to a 1/5th turn on the SV so I picked one up from Noel a while back.
    Install certainly seemed simple enough... went right in, had no issues, adjusted my throttle cables & it seems to work great... Full on, full off, snap back, looks good.
    Only problem is, the throttle stop is catching. If i roll to the throttle stop gently there's no issues, but if i ham fist it even a little, it sticks.
    Is there something I can or need to do to the housing or the throttle cam to prevent this?
    Re: Who has experience with throttle tube swaps?
    You beat me to the punch. That site is where I first read about the R6 tube mod.
    i've done a throttle swap on my gixxer. swapped to an 04 R1 which is 1/5th turn. The 06 R6 is a 1/6th turn, but i hear it requires a little modification to fit. installation was easy & takes 10 mins
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    I did the R6 swap and hated it. For the street, I'd probably go for it, but for the track, after it stuck on me once...it was off. I finally put the Euro Throttle from Yoyodyne on there. It's pricey, but much nicer and works much better.http://www.yoyodyneti.com/ProductInf...oductid=E80061
    Edit: I talked to a couple other SV guys up here who tried it and had it stick at various times as well. This was after the grinding and all. Some had it stick open, some closed. Mine stuck open briefly going into a corner and I almost hit the guy in front of me. Like I said...that was the end for the R6 tube. The only good thing was that I picked up my corner speed in that particular corner, which now gives me a better drive up the hill that follows it haha.
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Lifer obsolete's Avatar
    Norf Sho
    Trim like that site says. Did mine and love it.
    -Alex
    Quote Originally Posted by Puppet View Post
    Good to know... glad I'm trying it out at a track day & not a race environment first
    I rolled full on & full off MULTIPLE multiple times after I got it on there and it feels fine but I'll definitely be keeping close tabs on it. If it doesn't work I'll go back to the stock throttle tube & maybe modify that to have a larger cam.
    Member Pookie's Avatar
    Feb 2006
    Nashua, NH
    That thing better not stick on me!
    WHAT??? Who the hell said you were riding it????
    & where's my pics?
    Okay, you can ride it
    I went from a stock tube to a SV650 tube on the GS to quicken throttle, worked well. I went from there to a R6 tube, quicker throttle still. My first lowside with it the tube rolled back past the stop. Comparing the tubes, the R6 tube's stop isn't as tall, which stink's cause it was about the perfect turn rate on the GS. In the future I think I'll just get an R6 throttle housing so I know I'll have a safe setup.
    Lifer Punjistick's Avatar
    Norwell, MA
    Jul 2008
    Waitsfield, Vermont
    I've swapped the EX250 to an R6 throttle tube, and aside from my throttle cables now being a hair short, I've been pretty happy. It is a little fussy in installation, at least on the EX250; I suspect it's the lack of extra length in the cables, but it took me a few tries to get it lined up just right so the cable wouldn't bind and prevent the throttle from snapping shut. It never bound enough to prevent me from shutting it, but I figured tech wasn't going to like it much if I had cruise control going on.
    Oct 2004
    Seattle Area
    It didn't do it right away. I had done 3 or 4 trackdays and two race weekends before it happened
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Gotcha.... Good to know. I have my dremmel & the stock one with me now just in case... We'll see how the next two days go.
    Meriden, Ct
    Hmmm... I've been riding with an R6 tube on my SV all season. No issues, no sticking...
    Foxboro, MA
    Oreo, we are a yoyodyne dealer so let me know if you want to go that route.
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Will do, Denno.
    Th R6 tube worked pretty well at NJMP the last couple of days... assuming it stays like that I'll leave it as is.
    Meridinium
    did last year...... easy mod......
    BTW, thanks guys for the heads-up about the possibility of binding. I've only had my SV on the track 3 track days since I did the mod over the winter, but it will be in the back of my mind now.
  1. Replies: 47
    Last Post: 09-13-14, 09:35 AM
  2. For Sale - Parts & Tools | Daytona Clip ons, bar ends, 1050 throttle tube
    By 01xj in forum For Sale
    Last Post: 07-29-14, 08:15 AM
  3. WTB 99 GSXR 750 starter and Throttle tube
    By Sincere in forum Wanted
    Last Post: 07-06-11, 03:55 PM
  4. 1000RR Throttle Tube & Housing
    By Hazen in forum Wanted
    Last Post: 05-10-10, 07:35 AM
  5. WTB: 06 R6 Throttle Tube/Grip
    By MJD41985 in forum Wanted
    Last Post: 03-24-10, 02:03 PM
