Results 1 to 7 of 7
Gearing question?
    Gearing question?
    Trying to keep a swap from dirt to SM simple and quick.
    I have an 08 YZ450 that I use for some trail riding around the house and trackdays. When I get home from a trackday, I usually put the knobbies back on within a week or so.
    The stock offroad gearing is 13/48 and I used a 14/42 for the SM stuff. 14/42 seemed fine to me at NHMS last fall and was OK at VIR in the spring. For offroad, I switched out the front to a 12 which helped a lot in the woods.
    I'm swapping the bike now back to SM for the trackday next week and wanted to keep the 12 on the front, and found a new 38 rear from a KTM I had kicking around. Doing some simple math, the ratio seems very close if I use the 12/38 vs the 14/42, the 12/38 being just a bit lower. I guess my question is, is the smaller countershaft adding to much stress to the moving parts in the driveline? I remember reading in the past that a smaller countershaft adds stress to the driveline? I'm not to worried about it in the dirt because the tire is always spinning, there isn't much spinning going on at a trackday, at least not at my level of riding
    Thoughts?
    Thanks
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Re: Gearing question?
    Beet thinks you will be happy. ratio is ratio as long as your set-ups good........ Like in the TL case you can only go so small front cause of the clearance chain swingarm
    www.bostonmoto.com
    Forum Rules
    KB KB's Avatar
    Manchester NH
    Tully Most guys are running a 15 39 or 40 on those bikes if I recall correctly.
    Not sure if this is of any help to you.
    When I switch over the CRF back to Ice racing trim I run the stock dirtbike gearing. I have a ICE chain and a Track chain. Then it makes no matter what gearing you run as long as you have a chain for both.
    You comng up for the classic???
    LRRS/CCS EX #13
    GMD COMPUTRACK
    I ran something in that area on my 04 YZ that was a 4spd, the 08 is a 5spd.
    I have a 12,13,14,15, and 16, I guess I can just bring them all with me and adjust accordingly.
    I also have 2 chains, one for dirt and one for SM. Just trying to avoid the front sprocket change.
    I don't think I'll be up for the classic, but you never know
    KB KB's Avatar
    Manchester NH
    You can crash in the loft of the RV.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    live to ride seth399's Avatar
    Feb 2007
    CA
    hmm, not sure it would work out at Loudon but worth a shot if you can just bring the other sprockets. My 5speed crf I run 15/40.
    The part about smaller countershaft is true with having more stress on the chain. I have no experience with running a 12t front but you will see more chain stretch running a 12t vs 14 or 15t front sprocket in general.
    LRRS #399
    MX #505
    I took the bike for a couple laps "around the block" today with the 12/38. It seems a bit low and there was a minor front wheel loft problem in all but 5th gear. I'm going to change the front to a 13 tomorrow and do another couple laps. If the 13 seems ok, I'll just order a larger rear for the offroad stuff so I still won't have to swap the front.
    I'm also going to mess around with the jetting a bit tomorrow, seems to be running a bit lean
  1. 09 R6 Gearing
    By Sqzeplay74 in forum Pit Area
    Last Post: 04-05-12, 07:30 PM
  2. Gearing/Chain Length Question
    By tls25rs in forum Dirty Bastards
    Last Post: 10-01-11, 09:12 AM
  3. Gearing for VIR
    By kruse1022 in forum Pit Area
    Last Post: 01-23-09, 08:16 AM
  4. gearing
    Last Post: 05-23-06, 01:39 AM
  5. Loudon.....Gearing Question
    By By-Tor in forum General Bike Related
    Last Post: 04-24-05, 10:19 AM
