Results 1 to 25 of 26
Power Supply...
    Power Supply...
    I know we've got a coupla electricians here. What can we do about the power supply?
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    Re: Power Supply...
    If your talking about the track plug setup that they give you at the track, not much.
    If you tripping the circuit feeding that plug. Then you are overloading it and need 2’nd circuit, or one with a larger capacity, (20 Amps vs. 15 Amps ) You can figure that a 15 Amp circuit is good for about 1,500 watts continuous load 1,800 watts peak (intermittent) load. 20 Amp circuit good for 2,000 watts continuous and 2,400 peak. Add up the wattage of all the tire warmers used at the same time and you’ll know what you have and what you need for circuit capacity.
    Also keep in mind that unless they split the receptacle, both plugs on the same receptacle are on the same circuit. Don't know how the receptacle setup is at the track, but if you can you might want to setup between two of them and try to use both.
    Hope this helps,
    Jim
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    Lifer GMAN226's Avatar
    Coventry RI
    Power Supply...
    I brought this up last year. There is a 50 amp circuit up there with the larger plug style. I don't know the NEMA term for it but it's not a twist lock. If you can build a circuit breaker box with a cord you will have no problem
    G-man
    Gerard
    Dec 2003
    manchester, ct
    Power Supply...
    2 easy fixes for this ., on the pole there is noramlly a regular outlet ., that everyone uses !!! there is also a 20-30 amp plus that is still 110v ., it has 3 prongs on angles., you can buy an adaptor at walmart for $6 that converts that to a regular plug end to plug in your cord.,
    or you can use the 220v outlet 30-50amp., RV type., and buy a plug end and make a 4 gang outlet box just split off each leg so you have 110v to each outlet., i think they make a premade one ., but do not know where to get one., maybe a RV place.., i made my own., if you do not know how to make one ., do not try this...
    so you now have 2 options that work well because no one else uses those and they NEVER trip !!!
    if you want i can get a coupel of the 30amp round adaptors abd bring them with me next weekend., i usually have a spare or 2 anyway ., i gave them to all my teamates because they are all clueless., lol...
    women ??!!
    LRRS#989
    Power Supply...
    I know of which adapters you speak...
    I think we have a coupla peeps around here that could build wunna them boxes too...
    Thanks, yo!
    Power Supply...
    My boss just bought 2 of them things that plug in to the 220 posts, one has 3 prongs and one has 4. It also has a box with 4 110 outlets on the other end. I "may" be able to borrow these every weekend but i cannot count on it. I'll ask tomorrow to see how much they cost and maybe i'll pick one up.
    I think the front tire warmer draws 750 watts and the rear draws 800, at least that's what the ones i have say, so thats 1550 watts per set.
    aka Johnny Valve Stem need4speed's Avatar
    Aug 2002
    Brookfield,CT
    Power Supply...
    Mark let me know how much it costs and I will put in some cash towards it.
    John
    LRRS\CCS #714
    2004 Duc 620 monster racebike
    89 EX500 racebike - sold
    98 Superhawk 996
    "To repeat what others have said, requires education; to challenge it, requires brains".
    Walpole
    Power Supply...
    Putting something together shouldn't be too hard. If I get a chance to do a panel swap and there is a small sub panel heading for the trash I may make up a small panel to use with it.
    I would like to see what Mark has, and an RV place prolly has things allready pre made like someone said before.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Power Supply...
    Originally posted by PinHead
    ...an RV place prolly has things allready pre made like someone said before.
    I'm hoping for a cheaper alternative...
    ultrabuddy twrayinma's Avatar
    Apr 2002
    albukoikee
    Power Supply...
    i am shock-ed.
    Walpole
    Power Supply...
    I would like to see one and how they put it together. My concern if I make something up is weather and how it will do. Something from an RV place should be pretty weather tight and might give me some ideas.
    2000 Ducati 900ss
    Power Supply...
    I'll find out what the deal is with the one we have is, i know it came from a tool guy and not a RV place. We use it run a compressor off the generator and still have a separate braker for the shill saws and shit. Question is, is the post at the track the 3 prong twist type or the 4 prong twist type?
    Dec 2003
    manchester, ct
    Power Supply...
    the one at the track is a 4 prong., non-twist type., more like a dryer plug...
    women ??!!
    LRRS#989
    Power Supply...
    I'm gonna take a closer look at it Thursday at Tony's track day. Just wanna make sure I grab what we MAY need...
    May 2002
    New Bedford, MA
    Power Supply...
    If it's 50 Amps like stated earlier in the thread, it sounds like a range plug....
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    Posting Freak KevinB's Avatar
    Feb 2003
    Attleboro
    Power Supply...
    I'll check it out with you, maybe even donate so parts to the cause.
    Power Supply...
    Dec 2003
    manchester, ct
    Power Supply...
    very true.., the dryer is the 3 prong., and the range 4 prong correct., !~??
    i just go to the depot and buy the correct one., LOL.....
    what day is Tony's track day what date ?? hmm hmm ???
    women ??!!
    LRRS#989
    Power Supply...
    Ok, i checked out the one at my work today and i got the ok to use it anytime i need it. I thought he bought it with the generator he just bought, but he didn't. He went to home depot and bought all the parts and made it himself. Said it costs about $50 to make one like he has. I'm going to take it home with me monday, take it apart to see how it's wired, make a parts list and go buy the shit at the po. Either way, i'll have one with me for the next race weekend
    Aug 2002
    Brookfield,CT
    Power Supply...
    Like I said in an earlier post, let me know the cost and I'll split the cost with ya.
    John
    LRRS\CCS #714
    98 Superhawk 996
    Power Supply...
    I'm in for $10 towards it.
    degs
    Feb 2003
    Attleboro
    Power Supply...
    All the new style dryer and range outlets are now 4 wire, separate grounding and neutrals wires. Dryer is a 30 amp outlet.
    Power Supply...
    I'm in!
    Power Supply...
    Thanks for the offers
    I'll get to work on it during the week. My plan is to make it long ennough to reach the tent, this way we don't have a bunch of cords running everywhere.
    Power Supply...
    Sweet!!
  1. Metal supply store?
    By number9 in forum General Bike Related
    Last Post: 01-09-15, 05:55 PM
  2. K&L Supply Engine Stand
    By pcakes55 in forum For Sale
    Last Post: 12-19-12, 02:46 PM
  3. ATX Tower Case w/ 300w Power Supply NEW
    By VinceF2 in forum For Sale
    Last Post: 04-13-10, 02:22 PM
  4. Windows XP home + 400w power supply
    By Punjistick in forum For Sale
    Last Post: 01-22-07, 06:31 PM
