Results 1 to 17 of 17
Does this look ok?
    Just Registered Doc's Avatar
    Jericho, VT
    Does this look ok?
    Tried my hand at safety wiring today...
    Is this the general idea?
    Lifer Evil_Weasel's Avatar
    Over the Highside
    Does this look ok?
    i'm not quite sure what's going on in that top pic there????
    i'd have flunked that in my military aircraft mech days.
    Does this look ok?
    That's the idea, but if you're going to "wrap" twisted wire around the bolt head, like on that inner pinch bolt, the tension should pull the bolt clockwise (tighter), not counter. (see caliper bolts for correct tension)
    Does this look ok?
    I agree. Clockwise wrap........
    I also write the torque of the bolts everywhere. Good job on picking that one up. Black sharpie. Just do not use acetone. It disappears.
    Lifer smf's Avatar
    Nov 2006
    Does this look ok?
    we can fix any errant safety wiring the 21st ...and yes, that first pic looks very odd.
    Scott
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    Does this look ok?
    It looks like you anti-safety wired it. If one bolt loosens, they all do!
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
    Full Tilt - Full Time Trackday Guru's Avatar
    Dec 2006
    Concord, NH
    Does this look ok?
    LOL - nice effort though. For a "general idea" you did fine.
    Now get a little more "specific" and I think you'll be safe.......
    Mike
    Am #124
    Jericho, VT
    Does this look ok?
    Thanks for the tips fellas, I only stuck my self with the wire once.
    I WAS aware of the clockwise wrap... I'll redo that.
    Thank GOD all the bolts are already drilled.
    Does this look ok?
    NO! i tried that, it wont pass. play musical bolts until the holes face each other. the SW them together. or drill another set of holes. i tried the first and it worked for me. also put another hole in the axle so it doesnt matter how it threads in.
    Does this look ok?
    the axle actually looks OK but the others should be fixed. red is where holes should (kinda) be yellow is SW
    Jericho, VT
    Does this look ok?
    You gotta line the holes up? won't that over torque em?
    Lining the holes up would certainly help.
    Does this look ok?
    no, torque correctly, just wrap the tension clockwise.
    KB KB's Avatar
    Manchester NH
    Does this look ok?
    That looks like pooooo pooooo.
    Safety wired done properly will save your life. Hit someone up at the track they'll help yah out.
    But SVRACER01's got the right idea.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jericho, VT
    Does this look ok?
    I figured it was poo poo that is why I posted.
    Does this look ok?
    they dont like that. i did the old clockwise roation and they said "try again" their theory was if the SW reaches the other side of the bolt then what will keep it from loosening up? i understand it. so i just did as i pictured. dont over tighten just redrill or swap some bolts around until you get them close. the wire shouldnt reach the other side of the bolt.
    Dec 2003
    Ma
    Does this look ok?
    Quote Originally Posted by Paul_E_D
    Correct, make all the bolts pull tight.
    Oxx, i saw yours when they rejected, they were wrapped all the way around the bolt and could be pulled off the bolt easily and would have been useless.
    Does this look ok?
    you see nothing! his is like mine was (does that make sense?) just fix it! get them as close as you can. if you are going more than a 1/4 of the way around then it s too far. hows that?
