Results 1 to 4 of 4
LW Sportsman
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    LW Sportsman
    There was some talk this weekend regarding LW Sportsman and whether it's legal to run slicks. I copied the section from the rulebook on lrrsracing.com. For those of you that said they have to be DOTs...am I missing something here because I can't find it?? As I'm reading it, all Supersport classes and P-twins are the only classes that require DOT approved tires.
    Copied from the rulebook:
    SPORTSMAN - Sportsman machines are based upon production models, sold by manufacturers and their dealers in North America for street use. Proof of compliance rests with the competitor entering the motorcycle. Single cylinder machines are exempt from street use requirements. Single cylinder 2 stroke GP road race machines are not allowed in this class.
    All machines must have unaltered VIN numbers.
    1. All machines must meet the equipment standards of Section 5 and 7, as well as the following:
    A. Frame, head(s), cylinders, and engine cases must be from the same production model motorcycle.
    B. The frame must be as originally supplied by the manufacturer on the approved model. Strengthening gussets or tubes may be added. Only brackets or tubes not supporting suspension, engine, or drive line components may be removed. Swing arms may be modified or replaced and rear shocks may be replaced or relocated.
    C. Reducing engine size of machines from stock displacement to meet Sportsman class displacement limits is not allowed.
    D. Fairings that meet the requirements of Section 5 and 7 may be used.
    E. Liquid cooling is not allowed unless original equipment on the model being used.
    F. Original type of induction system must be retained. If a machine originally was sold with fuel injection, then it must remain fuel injected. If the machine originally came with carburetors, then it must use carburetors, however they need not be the original type or size.
    2. Sportsman Class displacement limits are absolute and are set as follows:
    LIGHTWEIGHT SPORTSMAN (Novice Amateur & Expert divisions)
    Single cylinder, unlimited displacement, production frame
    Single cylinder, up to 500cc, unlimited frame
    Two stroke, liquid cooled, up to 410cc
    Two stroke, air cooled, up to 550cc
    Twin cylinder, air cooled, non-desmodromic valves up to 700cc
    Twin cylinder, air cooled, desmodromic valves, up to 650cc
    Twin cylinder, air cooled, 2 valve, push rod, up to 895cc
    Twin cylinder, liquid cooled, up to 515cc
    Four cylinder, air cooled, 2 valve, up to 625cc
    Four cylinder, liquid cooled, up to 410cc
    NOTE: Ducati/Bimota/BMW Supermono, Woods Rotax, Yamaha TZR, Honda NSR & Aprilia RS machines are excluded from this class.
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    Nov 2003
    New Milford, CT.
    LW Sportsman
    You can definatly run slicks in LW Sportsman.
    CCS LRRS #454
    LW Sportsman
    huh, guess I was wrong... but i'm not surprised.
    KB KB's Avatar
    Manchester NH
    LW Sportsman
    Guess I was confused too!!!
    Thanks for the clarification fool!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Wanted - Motorcycles | Any smoking deals on Polaris Sportsman or similar?
    By tsorfas in forum Wanted
    Last Post: 02-17-22, 11:06 AM
  2. Sweeney #745 lightweight sportsman
    By Sweeneytuned in forum Pit Area
    Last Post: 09-30-13, 11:30 AM
  3. June LW Sportsman Race Video
    By lrrs428 in forum General Bike Related
    Last Post: 06-21-13, 07:47 AM
  4. Replies: 0
    Last Post: 08-06-12, 08:11 PM
