Results 1 to 12 of 12
Motard gearing for a 06 YZ450f NHMS
    Lifer lopycam's Avatar
    Aug 2003
    Cow Hampster
    Hi Guys,
    What is the gearing that you 450 5speed guys are running at loudon? I have a 2006 YZ450F and I am setting it up as a tard for a track.
    Thanks for the help.
    Nathan
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: Motard gearing for a 06 YZ450f NHMS
    I ride a crf but its a 5speed. I am running 15/40
    LRRS #399
    MX #505
    Nov 2007
    15f 39r on my CRF... is also what I think most people run with 450 5 speeds
    Zip-Tie Alley Racing
    LRRS/CCS #103
    15/39 on a KTM 520SX converted to a 6 speed, wishing I had more top end...
    Aug 2003
    Cow Hampster
    WOW that seems tall. Does the YZ have different gearing than the CRF? I thought Tully was using 14/42 on his 08 YZ?
    Thanks for the help guys.
    Nathan
    Nov 2007
    Not sure about the YZ but it should be similar
    Tully geared his for TDs in general, not specifically to Loudon I don't think?
    ANyways I'll double check mine but pretty sure it's 15/39 and it's a good mix of accel and top end. I am almost topped out going into the T3 chute and over the T8 hill... and top out around the 3/4 board on the straight but just carry it into 1.
    More importantly it gives me good shift points coming out of the bowl and in other spots as well.
    I think if you geared a tard for max speed on the straight at NHMS it would give you some pretty bad effects elsewhere on the track.
    LRRS/CCS #103
    Aug 2003
    Cow Hampster
    So, it sounds like I want around a 2.6 to 2.75 ratio. ( 39/15 = 2.6)
    Anybody else have anything to add?
    Thanks,
    Nathan
    Quote Originally Posted by ceo and a bunch of numbers View Post
    I geared mine for multi use, I ride it in the woods and do trackdays with it...and I hate changing the countershaft!
    For some reason, I thought I read the 08 had different internal ratio's?
    Last time at NHMS I used a 12/38 combo and I was pretty happy with it. Granted it was trackday pace in yellow group, guessing 1:30-1:35 lap times.
    The ratio seemed fine to me, good jump out of the corners and it never hit rev limiter on the front straight. The downside is, with the 12 up front, it destroyed my chain guide in one day.
    When I went to VIR in the spring, I had a 14/42 combo and that seemed ok at that track as well. Obviously the front straight sucked, but I doubt it would matter what gearing you put on a tard, it would still suck
    Nov 2007
    12/38? Holy shit!
    Yes I believe your 08 was quite different since it was a whole new bike pretty much... but in general all four of the big 4 were pretty much the same from 2000 up until then I believe...?
    LRRS/CCS #103
    Foxboro, MA
    Wow Chris is so knowledgeable in so many areas...
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    12/38? Holy shit!
    When I put the numbers together and added them up and divided by x, the final drive was very close to the same with the 12/38 on the 08 YZ450 5spd as it was on the 04 YZ450 4spd with 14/38. For what it's worth, 4th gear on the 04 with the 4spd is the exact same ratio as 4th gear on the 08 with a 5spd
    2000 and up? maybe close to some extent! I'll comment on the Yammy...well because I didn't know other brands exist
    2000-2002 YZ 426cc, steel frame, 4spd
    2003-2005 YZ 450, steel frame, 4spd (Motors had the hardest hit in these years, 03/04 being the hardest of the three)
    2006-2009 YZ 450, alu frame, 5spd with minor changes/improvements every year.
    2010 YZ 450 = I want one
    Nov 2007
    Quote Originally Posted by Crash Dummy Denno View Post
    Your mom has nice cans
    LRRS/CCS #103
  1. For Sale - Motorcycles | WTT 06 yamaha yz450f motard
    By sdog30 in forum For Sale
    Last Post: 02-24-17, 10:59 PM
  2. Wanted - Motorcycles | yz450f motard
    By sdog30 in forum Wanted
    Last Post: 03-23-14, 11:28 PM
  3. Gearing for NHMS
    By FireboltEric_MA in forum Pit Area
    Last Post: 12-18-09, 05:18 PM
  4. Motard guys, gearing..?
    By MysteriousR1 in forum Bike Maintenance
    Last Post: 06-21-09, 08:33 PM
  5. Motard Gearing *CRF450R*
    By BLACK SQUIRREL in forum Pit Area
    Last Post: 10-09-08, 02:51 PM
