Results 1 to 25 of 29
motard tire choice
    Registered Boozer PPS26's Avatar
    May 2007
    haverhill ma
    motard tire choice
    currently im using slicks in the frt and rear i dont experience too much chatter but comming into turn 1 and around 9 is the most. I know a few of the fast guys are using a d.o.t frt tire and slick rear... any feed back?
    Re: motard tire choice
    Not all slicks are created equal. What brand? And what kinda pace are you running?
    (Not that I have the ability to answer the question, but those that can could use that kinda info.)
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Quote Originally Posted by pps216 View Post
    I don't know any of the fast guys that do that...
    Motards chatter in the fast stuff. Try lightly holding down the rear brake to adjust your bikes geometry in these turns and eliminate the chatter. That's something the fast guys do.
    Slicks front and rear mang.
    Boston --> San Diego
    May 2007
    haverhill ma
    im running low 23s at this point... im using dunlop tires... and i talked to shane narbonne and he uses a 165 rear slick and a dot frt and loves it..
    Nov 2004
    Boston, MA
    I am not a fast guy but I have heard this to be a good combination for the tard...cannot recall where tho
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Slick rear, DOT front is definitely the way to go for fast tracks like NH.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Quote Originally Posted by mmracer37 View Post
    Well there you have it. Mike and Shane are undeniably fast.
    I bought my motard from Jeff with full slicks, and that's what Eric/Jeff now run on the CRF, along with JayRoot.
    Point: Seems there are options.
    KB KB's Avatar
    Manchester NH
    Mike can you elaborate on the reason for the dot front?
    Thanks,
    LRRS/CCS EX #13
    GMD COMPUTRACK
    less traction equals less chatter.
    Quote Originally Posted by rmbbikes View Post
    Thanks,
    Without getting too crazy on an explaination, Paul is correct. Don't think the chatter completely goes away, it just gets moved to a different level. With slicks on, my bike chatters brutally at 20's. As soon as I put a dot on the front, no more chatter until low 18's and it's not that bad (different frequency).
    So I'm going to bring this thread back from the brink. I noticed on the 520 that I was getting chatter all over the place, the biggest points being past the apex in 6, and down through 9. I was only turning 26s, and told I was way soft coming out of 6, I should be downshifting and hammering out, instead people thought I was lugging.
    Dunlop slicks front and rear.
    Tire, suspension, or just a technique problem? What should I be looking at first?
    I would measure The offset of the triples To start
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Still running my SuperSoft slicks front and rear. Stock triples. Chatter isn't a issue. Running low 20's and high 19's on the New Loudon.
    Diffrent bikes,
    when you say Chatter is not an issue Do you mean You feel some but can ride past it or you dont get it it all?
    Senior Member Pestilence's Avatar
    Salem MA - Soon.. Sandy Eggo CA!!!
    Quote Originally Posted by BLACK SQUIRREL View Post
    That was my first thought. Off-set triples completly changed the feel of my front end.
    -John
    "It's more fun to ride a slow bike fast,.. than to ride a fast bike slow."
    07 Husky SM510R
    That's what she said.
    Quote Originally Posted by Pestilence View Post
    CCS/LRRS #83
    Lifer lrrs313's Avatar
    Asheville, NC
    Check tire pressures first. What are you running hot? If I remember correctly I was running 32 or 33 in the front and 27 or 28 in the rear. And more throttle earlier helps a lot too.
    Quote Originally Posted by lrrs313 View Post
    Holy shits
    I run 26/27 In the front
    and 24 Rear
    Asheville, NC
    Holy shits
    and 24 Rear
    What brand tire? I was running dunlops last year, and those were hot temps. This year on Bridgestones im running more like 28-29 front and I think 26 rear, but those are cold temps. Every tire is manufactured differently (stiffer or softer carcass, different durometer rubber, etc) so the pressures vary a lot. I think I remember someone saying (might have been Denno) he was running around 23-24 in the Pirellis.
    Pirellis And dont have any Chatter issues (I also have the 8mm Offest triples)
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    I get a bit of chatter in 9 and before the apex of 10. not enough to be 'a big problem' thou. I just ride thru it. I've had it worse before.
    Posting Freak Puppet's Avatar
    Oct 2004
    Seattle Area
    If i remember correctly, I was running 30.5/28-28.5 COLD front and rear on the Katoom. Dunlop Slicks 16.5 front. The would put my front hot pressure about what Brian was running as well. I never really had bad chatter problems anywhere and was running mid 20's, low 21's when I left. The offset triples helped a ton as well.
    Remember to keep your hands REALLY loose on the bars. Because of the leverage of the bars on these bikes and the lightweight, you can really mess yourself up with too tight a grip
    Brian
    LRRS/CCS EX #881
    WMRRA EX #281
    KB KB's Avatar
    Manchester NH
    I hear the fast guys are running a dot front and a slick rear. I know nothing of this chatter that you speak of. Maybe it's there and I just ride around it, or maybe I'm just so fat and weight the bike down that I don't get it, or maybe I'm just slow??
    Can anyone explain this "chatter" stuff?? Maybe I'm getting it and I just don't pay attention.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Foxboro, MA
    Josh,
    Try a set of Pirellis and never look back. I haven't experienced chatter.
    Just switched a dunlop, a bridgestone and a michelin motard racer to pirellis this year - dunlop guy dropped 1.5 secs and eliminated chatter, bridgestone guy experiences slight chatter in 9 after feeling like a jackhammer on the stones in a bunch of places and michelin gent has dropped a 1/2 second and is getting no chatter at all.
    Stop by the trailer and let's be even closer friends...
    #49
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    KB KB's Avatar
    Manchester NH
    Denno we all know you want everyone to run Pirelli tyres but can you explain chatter for us tards?
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. What would your choice be
    By jcbell1007 in forum Pit Area
    Last Post: 06-23-11, 11:00 AM
  2. Motard Tire choices
    Last Post: 08-11-10, 03:59 PM
  3. Motard tire deal from Boston Moto
    By Boston Moto in forum Pit Area
    Last Post: 07-23-08, 12:10 PM
  4. Motard Tire Advice.....
    By Manny in forum Dirty Bastards
    Last Post: 12-19-06, 10:37 AM
  5. Tire choice?
    By RSVMILLE661 in forum Pit Area
    Last Post: 09-16-05, 09:49 PM
