Results 1 to 25 of 46
Motard wiggle
    Jun 2005
    Motard wiggle
    So, my KTM was doing quite a bit of dancing yesterday... not quite sure what's going on... Maybe it's just a happy dance.
    If I get a good drive out of 12 and some decent speed (for a motard) on the straight, the bike starts to wag back and forth quite a bit as it tops out by the 4 board.
    First thought is holding the bars too tight, but that's not it... I was rocking the one-handed flat track stylie with just my right thumb ad index finger (lightly) holding the throttle open.
    Head bearings are adjusted properly, wheels are straight, bike has a Scotts steering damper... turned that up a bit, bike still just wants to dance when it sees the boards.
    Felt like a slow-mo tank slapper. Definitely an oscillation. Nothing major at all, settles itself out when I slow for 1... just didn't really do that last year. Everywhere else is good. Little shake over the hill, same as last year.
    You tard guys have similar shakes?
    Re: Motard wiggle
    Seems the new Brakes are the only Variable, I am having Nothing like you describe
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Re: Motard wiggle
    Quote Originally Posted by BLACK SQUIRREL View Post
    I also am having nothing like you describe.
    Boston --> San Diego
    Member clutch's Avatar
    Oct 2008
    Re: Motard wiggle
    I had the same kind of problem with my SM. Tweaking the steering damper took it out for me.
    Now its smooth and straight.
    Re: Motard wiggle
    That happens on bikes with too little trail. Have you swapped out your triples yet?
    live to ride seth399's Avatar
    Feb 2007
    CA
    Re: Motard wiggle
    I'm pretty sure I am not experiencing this either but I was behind the kid on a kx450f for several laps and his bike was wagging back n forth like crazy, same as you describe
    LRRS #399
    MX #505
    Jun 2005
    Re: Motard wiggle
    Yeah, Tri-star 8mm joints.
    I rode Mike Green's CR500 for a session and that actually did it as well, so the possibility (always) exists that I'm inducing it somehow...
    Feb 2007
    CA
    Re: Motard wiggle
    did you have swamp sack? maybe they were both hanging to the right or left?
    LRRS #399
    MX #505
    Jun 2005
    Re: Motard wiggle
    two laps on that 500 guarantees swamp sack... and blurred vision, and loose fillings... and a HUGE grin.
    Tucson, AZ
    Re: Motard wiggle
    Quote Originally Posted by seth505 View Post
    I was thinking he was doing the Lean wit it, Rock wit it.
    Original
    Feb 2007
    CA
    Re: Motard wiggle
    that thing must be so sick...but on topic, this is an interesting issue because I saw that other bike doing it too and it seemed real weird to me
    LRRS #399
    MX #505
    Re: Motard wiggle
    Motards are weird.
    KB KB's Avatar
    Manchester NH
    Re: Motard wiggle
    I had this happen 2 seasons ago. It was actually the rear tire. How's the tires?
    Paul I say Motards are good. Real bikes are weird. I can't get used to that damn SV. I ran faster lap times on the tard.
    Mike I heisted some TrickMikeJoint stickers from union. Next time you're at the track drop by with some!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jun 2005
    Re: Motard wiggle
    Good point. Tires are about at the end of their rope for sure. So that's a good place to start even if that may not be the problem. They need replacing anyway.
    Lifer Pittenger5's Avatar
    Austin
    Re: Motard wiggle
    My front end gets mad light on the straight, maybe cause I weigh 83 pounds. If I tuck in as best I can the front end plants pretty well. Maybe try tucking a bit?
    Zip Tie Alley #505
    KB KB's Avatar
    Manchester NH
    Re: Motard wiggle
    Tucking? You mean like a tranny?
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jun 2005
    Re: Motard wiggle
    Someone say "tucking?" DB are you a pre-op?
    Feb 2007
    CA
    Re: Motard wiggle
    ahahahahahaa
    LRRS #399
    MX #505
    Austin
    Re: Motard wiggle
    I have nothing to tuck
    ahahahahahaa
    Zip Tie Alley #505
    Austin
    Re: Motard wiggle
    Seriously, for once I try to bring a serious response and the talk STILL turns to my penis. How does this always happen?
    Zip Tie Alley #505
    Meriden, Ct
    Re: Motard wiggle
    I noticed alot of the 'tards doing the same thing. Down the strait, some oscilation in the bars... For what it's worth. Every DR-Z400SM that I test ride does it over 75mph...
    Providence,RI
    Re: Motard wiggle
    I have been thinking about this since yesterday. It is interesting to me that I don't really have a problem with wobbling on my cr, and you do. I don't know if this is just that I have learned to ignore it, or maybe the difference in weight. I know that when I come out of twelve I slide back in the seat to put more weight on the rear end. I had a damper on my drz,which I haven't ridden at the track in forever, and it wobbled a lot, but I have never felt the need for one on my other bikes. We go about the same speed so I would expect us to have similar a experience on the same bike.
    In any case it was a great day, can't wait to do it again. Glad you liked the cr. you can ride it anytime.
    Mike Green
    LRRS #450 novice
    http://www.mikegreensculpture.com
    '06 svx550
    '04 cr500 af le
    '04 525 smr
    '02 660 sms
    '01 drz 450 sm streetbike
    '99 r7
    '99 sv650
    '86 rg500
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Re: Motard wiggle
    this is interesting mike. I dont have it on mine with 14mm offset and topped out in 6 just past the start finish (so im full bore for a little bit). Im not really sure what you could be doing since you barely have cntact with the bars (could this be the prob?? ) Although I do both hands as well as the full tuck one hand behind back. I would check tires and brakes since those seem to be variables as others have said. Does it happen anywhere else that it didn't before?
    Zip Tie Alley #237
    Dec 2003
    Ma
    Re: Motard wiggle
    I get the wiggle sometimes. I'm guessing it could be from holding too tight sometimes or popping up before braking and having that wind make the front even lighter. I have no damper.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Re: Motard wiggle
    How far back on the seat do you get? I notice lots of motard guys sit way too upright on the straights and stuff. Your body is a big fat sail.
    Compare this to my competition...
    Sorry I can't find the fullsize pic but Jeff Wood (hey that's my RMZ!!) tucks the same way on his motard. Eyes just peeking over the triple clamps. See tiny pic.
  1. Help me fix my Motard.
    By JettaJayGLS in forum Bike Maintenance
    Last Post: 09-22-13, 05:45 PM
  2. The soon to be Motard
    By MysteriousR1 in forum General Bike Related
    Last Post: 12-13-08, 10:09 AM
  3. Who was on the motard?
    By 13 in forum General Bike Related
    Last Post: 03-19-07, 04:45 PM
  4. Motard - Which One and Why?
    By Currently in forum General Bike Related
    Last Post: 10-31-06, 11:24 PM
