Results 1 to 23 of 23
Mounting transponder
    Newbie DZircher's Avatar
    Oct 2012
    Cambridge, MA
    Question Mounting transponder
    I was wondering if anyone could make a recommendation of the best place to mount the mylaps transponder on the 848?
    Much appreciated!
    -Diz
    -dana
    LRRS NOV #358
    http://DucatiRacerChick.blogspot.com/
    There's truth and charm and beauty
    And strangeness everywhere
    The closer we examine
    The more there's nothing there
    Lifer union's Avatar
    Blackstone, MA
    Re: Mounting transponder
    Most will mount them on the forks.
    James
    Left fork below the top triple....like every other bike?
    Oct 2012
    Cambridge, MA
    I'm not certain that it will have enough clearance from the skins, do you mount it on the outside of the fork, the front or the rear?
    -dana
    LRRS NOV #358
    Blackstone, MA
    Quote Originally Posted by DZircher View Post
    doesnt really matter as long as it doesnt interfere with your steering
    James
    Blackstone, MA
    You can see my transponder just under my clutch lever. Miles will have mounts at the track if you need one.
    Yellow zipties on left fork leg. Thats the mount
    James
    The staff that scans them on pre-grid prefer that it goes in the front facing forward. Use zip ties to mount the bracket to your fork tube. Then wrap it in painters tape so the bracket doesn't freely spin.
    Oct 2012
    Cambridge, MA
    @union Thanks for posting those pics, that help enormously. - Diz
    -dana
    LRRS NOV #358
    Blackstone, MA
    If you want to come out to the shop one of these weekends and go over some of the smaller stuff let me know. I dont have my R6 anymore but a bike is a bike.
    James
    On the end of a 10' pole, tied to a C class rocket motor wired to the horn button for those 'close' races.
    Durham
    Iirc there was a change to the type of transponder not too long ago. Having recently gotten one in trade how do i make sure I have the right type? I'm asking mostly because what I have (wired not battery) does not appear to have any provision for a mounting bracket. It does have tabs with holes on the bottom that I assumed are for mounting so i was just going to ziptie it to the fork leg.
    There was no change to the type of transponder recently ian. The rest of ccs changed to westhold, but lrrs and ama both use amb.
    I don't know what the wired ones look like, but the wireless ones have a mount you can get from miles at street and comp.
    Durham
    Ah ok it was the ccs thing I must have been thinking of.
    mine was mounted on the top triple tree next to the key.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Quote Originally Posted by soofle616 View Post
    I have the wired one. just zip tie through the holes and throw some tape around it so it doesn't turn around the fork leg and you're good.
    Durham
    thanks, thats what I figured, just wanted to make sure.
    FYI, the change is for all CCS regions except North East. so if you plan on racing at NJMP or anywhere outide of NHMS, you'll need to rent a Westhold for $25/weekend or buy one for $80.
    Oct 2005
    Wrentham MA
    what others say - the front forks pointing down towards the track is correct...
    the full description on mounting is:
    "Transponders must be mounted at the front of the motorcycle as close to
    the axle vertical center-line as practical. They must be mounted vertically,
    with the fixing pin up, at a maximum of 120cm or 4 feet from the race
    surface with no obstruction downwards. This means NO metal or carbon
    fiber between the transponder and the track surface. The maximum
    temperature should not exceed 50c or 122F. The holders should be fixed
    in a safe and workmanlike manner using tye-raps or pop rivets. The fixing
    clip should be pushed through the post as far as possible."
    For some reason the 2012 rule book in section 7.16 stated see section 19 for mounting- but the above was missing....
    We will correct this going forward...
    p.s. just because it isn't in the current rule book does not change the facts....
    Graham
    Oct 2005
    Wrentham MA
    fyi - the where to mount the transponder is now in the 2013 rule book.
    Graham
    Blackstone, MA
    Quote Originally Posted by xsiliconkid View Post
    is there a plan to have this rule book in our hands before racing starts?
    James
    Feb 2004
    Yes! Very soon!
    Johnny B. (the other one) ®
    Oct 2005
    Wrentham MA
    2013 LRRS rule book should be up on the web site under downloads either today or tomorrow...
    http://www.nhms.com/events/lrrs/
    Graham
  1. MA plate mounting
    Last Post: 08-14-09, 02:54 PM
  2. Transponder mounting location
    By eboos in forum Pit Area
    Last Post: 02-21-08, 08:04 AM
  3. Tire Mounting CT
    By VenomXX in forum Bike Maintenance
    Last Post: 03-10-07, 03:31 PM
  4. Lap timer IR mounting?
    By brewmaster in forum Pit Area
    Last Post: 07-18-06, 02:14 PM
