I was wondering if anyone could make a recommendation of the best place to mount the mylaps transponder on the 848?
Much appreciated!
-Diz
-dana
LRRS NOV #358
http://DucatiRacerChick.blogspot.com/
There's truth and charm and beauty
And strangeness everywhere
The closer we examine
The more there's nothing there
-dana
LRRS NOV #358
@union Thanks for posting those pics, that help enormously. - Diz
-dana
LRRS NOV #358
On the end of a 10' pole, tied to a C class rocket motor wired to the horn button for those 'close' races.
Iirc there was a change to the type of transponder not too long ago. Having recently gotten one in trade how do i make sure I have the right type? I'm asking mostly because what I have (wired not battery) does not appear to have any provision for a mounting bracket. It does have tabs with holes on the bottom that I assumed are for mounting so i was just going to ziptie it to the fork leg.
Smelly Dog Racing - Website - Facebook,
LRRS AM #604 | DP Brakes | Race Tech | Spears Racing | All Balls Racing | Woodcraft | Armour Bodies | Spectro Performance Oils | Zero Gravity | Kabuto Helmets | Shorai
There was no change to the type of transponder recently ian. The rest of ccs changed to westhold, but lrrs and ama both use amb.
I don't know what the wired ones look like, but the wireless ones have a mount you can get from miles at street and comp.
Ah ok it was the ccs thing I must have been thinking of.
mine was mounted on the top triple tree next to the key.
LRRS Am #331
what others say - the front forks pointing down towards the track is correct...
the full description on mounting is:
"Transponders must be mounted at the front of the motorcycle as close to
the axle vertical center-line as practical. They must be mounted vertically,
with the fixing pin up, at a maximum of 120cm or 4 feet from the race
surface with no obstruction downwards. This means NO metal or carbon
fiber between the transponder and the track surface. The maximum
temperature should not exceed 50c or 122F. The holders should be fixed
in a safe and workmanlike manner using tye-raps or pop rivets. The fixing
clip should be pushed through the post as far as possible."
For some reason the 2012 rule book in section 7.16 stated see section 19 for mounting- but the above was missing....
We will correct this going forward...
p.s. just because it isn't in the current rule book does not change the facts....
Graham
fyi - the where to mount the transponder is now in the 2013 rule book.
Graham
Yes! Very soon!
Johnny B. (the other one) ®
2013 LRRS rule book should be up on the web site under downloads either today or tomorrow...
http://www.nhms.com/events/lrrs/
Graham
