Results 1 to 20 of 20
My own (much less ambitious) track trailer build - start with vent placement question
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Hi all,
    I bought a 6x10 v-nose all aluminum CargoPro trailer.
    I bought a 14" roof vent, all the sealant / screws / putty tape that you're supposed to have and one of those Maxxair II Vents.
    Humor me here....because I want to make sure I'm happy with where the vent is before I go and cut a hole in my new trailer.
    I was looking at other people's trailers during LRRS 5, and it looks like most have their vents right in the middle. Since my trailer has a 6'1" inside height, and since I'm ~6 ft, I don't have a lot of clearance though, and I'm worried if I put it in the middle I'll keep bumping my head when I walk around in the trailer. I marked off a 14" square hole to cut out in the second full beam space, but I'm actually thinking of moving it up all the way to the first beam space. It's got a 12" V, so it wouldn't be right on the edge of the trailer, but I'm worried it might look retarded to have an appendage sticking right on the front of the top - that maxxair II is fairly big.
    Maybe I just need a little encouragement before I cut a big hole in the first brand-new road-going machine I've ever owned.... but does anybody have any thoughts?
    I might be able to post pics later if that helps....
    LRRS 919
    Re: My own (much less ambitious) track trailer build - start with vent placement ques
    Just cut the hole. You'll feel better after. As for your worries of bumping your head, first world problem. No different than going down to the basement in 98% of the houses in New England.
    TWINS! xrocket21's Avatar
    Central Maine
    I say put it in the front
    measure once, cut 4 or 5 times, right?
    Austin, Tx
    Look at it as a positive - all those happy accidents are "adding lightness." It is a "race trailer" after all.
    '14 Aprilia Tuono - crack on 2 wheels, '14 Ninja 300, '04 BMW M3
    Sep 2013
    Quote Originally Posted by TrackRat View Post
    Uhhh...yeah...as if my own carpentry skills weren't going to make this fun enough, I picked up your brother's sawzall last night and to his earlier comment of:
    "Make sure you wear rubber shoes when you use it, its got a wire loose or something"
    he has now added:
    "Plug it in and it just goes, the trigger switch doesn't really work."
    ...if anyone wants to see me seriously hurt myself, this is shaping up to be quite a show.
    LRRS 919
    Austin, Tx
    he has now added:
    Dude,
    Seriously, wait. Using my brother's tools may result in you not making it to Loudon, next weekend, and possibly an extended visit with the staff of the local emergency room. Stop by on your way to NYST, or on your way back, and I'll hook you up.
    Hell, stay in Albany, Friday night. I think I'm free.
    Sep 2013
    Dude,
    You're right. Not sure safety wire and duct tape work so well for reattaching fingers and toes.
    Donno if I'm going to NYST this weekend. Might just use the Dremel to make the hole. How long do you think it would take to make a 14x14" hole in an aluminum roof with that?
    LRRS 919
    I got a bunch of saws & grinders if you need help, too.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Put the vent where you want. After you bump your head a few times you will instinctively duck your head. Trust me on this. I know.
    he has now added:
    I have a variable speed Dewalt with no such issues if you want to come by Savin Hill, near UMass Boston.
    Sep 2013
    I might take you up on that.... You around this weekend?
    LRRS 919
    Sep 2013
    Ok - so I think I have a plan for the roof vent.
    On to the next problem to solve -
    When I bought the trailer, I had it in my mind to fix up sleeping arrangements by putting some sort of rack on the wall that would be hinged on one side, then the other side would hang from the ceiling.
    If figured I'd be able to find some sort of aluminum framed rack through a military supply or something - almost like a cot without the legs.
    Not sure if I had seen that before elsewhere or how I got it into my head that they existed, but no luck finding them, at least online. I can't just cut the legs off of a cot, at least the one I have, because the frame is held open by the legs being supported on the ground.
    it almost seems like I might be able to rivet together an aluminum frame, and then stitch some nylon or whatever they make cots out of across it - but I've never done anything like that before.
    The advantages of doing this are that if I set one of these up high enough off the floor, I can put another one below it (or just have space for a cot below it) and be able to roll 3 deep in the trailer (this has already been needed once, and will likely be needed again at the next LRRS round).
    Any ideas on either where to find a pre-made rack, or thoughts on my plan of building one?
    LRRS 919
    Does this work for you: http://www.modulinecabinets.com/folding-couch.html
    In use: http://www.expeditionportal.com/foru...Hauling-camper
    Also this: http://www.basspro.com/Disc-O-Bed-Ca...1304230721363/
    I've also seen some really neat stuff made out of that 80/20 aluminum stuff.
    Not that I've given any of this any thought...
    My own (much less ambitious) track trailer build - start with vent placement ...
    Very simple:
    Measure the desired size of an air mattress. Build 2x4 frame and deck it with plywood. Hinge frame off of trailer wall. Determine frame height when bed is deployed, cut several support legs to this length and attach them bed frame with a single nut and bolt so they also hinge.
    Marcelo, post a picture of your junk.
    To keep the weight and space down, I'm wondering if 2x3's wouldn't be enough for a bunk, even a double sized bunk.
    I think the extruded aluminum would be even better weight/space savings.
    Another idea.
    http://www.doityourselfrv.com/diy-rv...bed-madmumsie/
    http://iamsamthevan.blogspot.com/200...g-sofabed.html
    Sep 2013
    Re: My own (much less ambitious) track trailer build - start with vent placement ...
    Very simple:
    Thanks guys, this gives me some ideas. The important thing is you've helped me to locate a source for the nylon matting already sewed up (one of the things I was worried about doing myself) and some options for building the frame.
    LRRS 919
    Austin, Tx
    I'm liking that option from the Bass Pro Shop. Any idea of what their return policy is?
    Sep 2013
    I suppose that depends on how much sawzall is required to work it into the design....
    LRRS 919
    There's this option, but I don't know where these guys get them.
    http://www.nhtrailers.com/Options/FoldUpBed.htm
    High maintenance priss
    Central MA
    Quote Originally Posted by Aprilia Pilot View Post
    I've bought parts directly from ProLine in the past; they might sell that bed assembly.
  1. Track Trailer Build
    By loudbeard in forum Pit Area
    Last Post: 03-23-15, 10:52 PM
  2. winter project - track trailer build
    By isaac_ in forum Pit Area
    Last Post: 01-06-15, 11:42 AM
  3. Trailer Build
    By Jim in forum General Bike Related
    Last Post: 07-30-14, 03:24 PM
  4. Need some advice on bike placement on a trailer
    By Evadd in forum General Bike Related
    Last Post: 05-20-12, 09:22 PM
  5. Track day group placement???
    By nilez in forum General Track Day Talk
    Last Post: 04-11-08, 12:09 PM
