Results 1 to 13 of 13
Palmer SV Gearing
    Feb 2011
    Newport, R.I.
    Palmer SV Gearing
    Riding palmer for the first time next month on an SV. What does everyone run for gearing there???
    Re: Palmer SV Gearing
    i rarely change my gearing. i run 14/44 almost everywhere. VIR i go up a tooth in the front which is really just the stock set up. id probably try that at NJMP as well although i did run it with my usual gearing with no issues
    Feb 2011
    Newport, R.I.
    15/46 is where mine is now so im assuming i can leave it alone?
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Quote Originally Posted by Duffy21690 View Post
    Yup
    I enjoyed using 6th gear on the front "straight" with my stock 15/45 gearing. Yes, I was passed by bikes with much more power, but the gearing was fine.
    I still don't get why you run that 14 tooth front
    Wheelies, yo. Also, 44 divided by 14 = pi.
    False. 44 / 14 = 22 / 7 = 3.1428571.
    They taught me in 4th grade that this was Pi.
    They fucking lied to me.
    I think all schoolchildren should be taught gearing. And computing compression ratio, while we're at it.
    And also the Ideal Gas law. When Deflategate first hit I couldn't fucking believe the amount of people who have no idea how basic physics works.
    Both static and dynamic compression ratios, and how the CR alone does not determine what octane you need, nor can you determine CR based on a compression test...
    This. When it came to building my '69 El Camino small block, I had no idea how much I didn't know. I could get 10.0:1 compression with a thick head gasket and bad squish numbers, or a thin gasket and good squish -- so long as I had the right pistons. And even this is just the static side of the things, I'd need to plug in my cam numbers to get dynamic!
    Feb 2011
    Newport, R.I.
    Haha this went way off topic but thanks guys Im gonna leave the sprockets alone for now.
  1. Palmer 7-25/26 With Evolve GT
    By Brendin87 in forum General Track Day Talk
    Last Post: 07-14-20, 05:38 PM
  2. Howdy from Palmer, MA
    By TwelveGaugeSage in forum Welcome and Intro
    Last Post: 05-29-17, 02:39 PM
  3. Palmer day with Fishtails.
    By Tricklidz in forum General Track Day Talk
    Last Post: 09-06-16, 07:03 AM
  4. Palmer Hotels?
    Last Post: 07-27-16, 11:29 PM
  5. Track in Palmer...
    By senecak19 in forum Pit Area
    Last Post: 04-04-09, 03:03 PM
