Results 1 to 25 of 37
passes
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    passes
    here are a couple clips from this weekend - I'm not into making people watch 10 minutes of laps... Camera was off for a pretty cool Pass around 103 (gsxr1000) in T3, but here's a couple I caught...
    http://www.youtube.com/watch?v=NBh7XJELqR4
    Lifer Kenn157's Avatar
    Saddlebrooke AZ
    Re: passes
    SWEET! I saw 161mph!
    LRRS/CCS #627 JRide's Avatar
    Sep 2006
    Simsbury CT
    Re: passes
    Haha, looks like you're in fast forward compared to my laps.
    Cool vid. What's your gearing from stock?
    John
    04 KTM 125SX
    05 CBR600RR
    07 KTM 250XC-W
    Feb 2009
    Lost in constant migration
    Re: passes
    Thanks dude, that's some useful stuff for a novice like myself.
    I have a question though. There's something odd going on in that video. Your bike makes some kind of noise and surges forward... what is that? Could you explain?
    Re: passes
    Worrrrrd. I gotta get my camera system back up & running.
    Lake Champlain, VT
    Re: passes
    Quote Originally Posted by "Dangerous" Dan K View Post
    yea, that is just the see-see's working... an EX doesn't have those... so don't get all tangled up in that
    Lake Champlain, VT
    Re: passes
    haha, gearing is off stock by 13%, so I suppose 161 = 141.5
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: passes
    Speedo's on race bikes don't mean much, the way the gearing is for Loudon sends them off quite a bit. The main straight is probably 135mph or so. That's why you see a lot of guys say "indicated" and use the speedo just for comparison's sake.
    Sweet vid tho man. 'Grats on the 16's
    Lake Champlain, VT
    Re: passes
    yea, I def do this to see if I'm clicking off any extra speed... I could get by with just a tach, or with nothing at all, but the MPH are a nice marker to help with making improvements around the track.
    Saddlebrooke AZ
    Re: passes
    Ah! Was still fast though!
    Member yammy644's Avatar
    Nov 2003
    Dartmouth, Ma
    Re: passes
    Nice slow motion for the bump pass in 11...
    Tim
    LRRS #46 EX
    windmillcycles.com
    Re: passes
    Nice! What happened in 11 there near the end? Lose the front? hit the curb?
    Lifer Pittenger5's Avatar
    Austin
    Re: passes
    You fast guys are fucking nuts.
    Zip Tie Alley #505
    Lake Champlain, VT
    Re: passes
    Timmy Barber was trying to get around me, my line brings me to (almost) the curb, tim said his bike slingshot off the curb and into mine... it was def a pucker moment, because I always feel like im on tip-toes over there anyway...
    My first guess was that bergs was riding his bike for that race, but then I reminded myself... if that were the case, he wouldn't have been passing me
    Re: passes
    That's the toughest section to feel the limit IMO. A slightly tighter entrance is safer. If someone can pass you on the outside there, they are a lot faster than you through the entrance. If you're slow at the entrance, and use a wide line, those guys *should* pass up the inside, but often don't, leading to contact at the curbing.
    Anyway, leaving a bike width on the outside is good.
    Lake Champlain, VT
    Re: passes
    Leaving the door open for people? doesn't sound right... I'm not as concerned with the passing wide, it's more the getting stuffed for 11a that screws up the entire drive down the straight... A pass on the outside of 11 can essentially cost you a few positions.
    If somebody can thread the needle and pass on the inside, that's great, however, unless they are MUCH faster, I still own the line in 11a... Now when Wood and Greenwood pass me there, there's enough speed differential where I am not affected.
    Nov 2003
    Dartmouth, Ma
    Re: passes
    Yeah I got a great drive out of 10 and tried to get by on the outside, there was plenty of room 1 second and then there was none. I stood the bike up and braced for the curb and Kitt. I hit the slope of the curb and bounced off Kitt, then backed off and ran wide to give Kitt some Holy Shit room.
    Tim
    LRRS #46 EX
    windmillcycles.com
    Re: passes
    Ever seen someone get taken out there? it's not pretty. My philosophy is if you don't need the whole track, don't use the whole track. It's faster to take the shortest way around the track that you can for your given pace. Plus, someone out there needs the whole track for their pace.
    Lake Champlain, VT
    Re: passes
    Staying off the outside curb before T11 would make it a harder, tighter turn, over what can be a bumpy/weightless ride... The wider I enter, the better I can negotiate 11 and set up for 11a...
    I will def watch some faster guys and see what they are doing, and try a couple lines out in practice.
    I got a chance to follow tim through that section, and there was a big difference in the direction of his drive out of 10, which set up for some major differences - this could change the way I look at the entire back section.
    Re: passes
    Well, a few thoughts: maintain the highest possible entry speed into 11 that you can. Setting up for 12 is almost pointless as there's nowhere to go. stuff it in there any way you can and drive out as early as you can. Tight in (relatively), wide out of 11 is very fast and protects 12 because the guy on the outside of 11 is screwed, if he can even get beside you, he'll be quickly pushed into the marbles...
    Canterbury, NH
    Re: passes
    I'm kinda with Paul on this one... T11 totally entry focus. You can brake later/harder and take a slightly tighter line without being passed, and drop your lap times all at once by carrying a slight bit of extra speed. Setting up as wide as possible forces you to get on the binders a bit earlier. Of course a tighter line leaves an outside pass open, but only if they're fast enough to get around you safely... in that case, they're probably going to get around you eventually anyway.
    In this instance, you two had the hardest fought battle going on in the entire race and you guys weren't even technically racing each other lol
    Ambition Outweighs Talent strgt's Avatar
    Jun 2009
    Re: passes
    Quote Originally Posted by JRide View Post
    Thought the same thing
    www.streetandcomp.com
    LRRS/CCS/WERA Am. #290
    NESBA Adv. #290
    Re: passes
    Hey!! What the....
    HEY!!!!
    Lake Champlain, VT
    Re: passes
    Quote Originally Posted by Butcher Bergs View Post
    Hey!! What the....
    HEY!!!!
    don't worry, I know it won't be you for the next race either - because you are going to WATCH instead!!! Can I quote you're "To me, a real racer is..." speech? lol
    Re: passes
    Here we go again...
    Quote away if you must. Broken gearbox tends to make racing difficult, not a couple cones and some large blue pillows.
  1. 4 Passes to F1 Racing in Braintree
    By loridin64 in forum For Sale
    Last Post: 12-16-10, 04:41 PM
  2. Will ECK have discount passes this season?
    By The Snowman in forum Pit Area
    Last Post: 05-25-10, 05:58 PM
  3. LRRS Passes
    By gmdboston in forum Rides & Events
    Last Post: 06-30-04, 03:13 PM
