Results 1 to 12 of 12
Why do they push the motorcycle?
    Member Variablevalve's Avatar
    Boston, MA
    Question Why do they push the motorcycle?
    So I was watching Closer To the Edge last night, and I saw that they always seem to push the motorcycles out of the pit.
    Example here: http://www.youtube.com/watch?feature...wzCP_89s#t=49s
    Could anyone explain to me why this is done? I can't seem to find any answers through a normal google search.
    2000 Suzuki Bandit 600
    1978 Suzuki GS550E (Project)
    Re: Why do they push the motorcycle?
    Most are total loss (meaning they don't hold a charge) so they need to bump start the bikes because they don't have starters.
    Boston, MA
    Thanks, that makes a lot of sense. I'm guessing it's done as a weight saving measure?
    Weight savings is the principle, but reducing rotating mass inside the motor (flywheels and stators) to allow the motor to spin up faster and/or make more power is the main idea.
    Because I know Graham is lurking.
    http://www.nestreetriders.com/forum/...-flywheel.html
    I have a total loss system and retain my starter but have no stator.
    It all goes to less weight
    Think of a chain saw or weed whacker with a pull starter. They just have to push start theirs. . Similar principals can be applied to a bike.
    Good read. And by idea in my last post, I guess I meant marketing.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Save the clutch
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    keep time off the motor.
    -Benjamin Franklin
    I thought most bikes at the IOM TT have starters... If you look/listen closely to that video, I'm fairly certain he fires it up with a starter.
    If they don't have a starter, they're bump starting it.
    If they DO have a starter it's to:
    Save the clutch
    Get them out quicker
    And perhaps also to make sure they don't stall out.
    May 2007
    Southern NH
    The example you showed was Guy Martin. There's no telling why he had has bump started...he could just as well have used a steam engine to drive a roller starter!
    Muhammad Ali.
    In some cases, the SV650 is a good example, the crank is a weak point, which often fails under a lot of use. Lightening the stator rotor, or removing it altogether (like was done to mine) lightens the lad that is placed on the crank.
    So, in this case, it's for durability.
    Meridinium
    So, in this case, it's so I can eat more donuts.
    there.. I fixed it..
  1. I need a push.
    By zxme in forum General Bike Related
    Last Post: 06-13-11, 10:16 PM
  2. Quick shifter push type
    By dudutzu in forum For Sale
    Last Post: 08-15-10, 08:45 PM
