Results 1 to 23 of 23
race bike prep...
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    race bike prep...
    started the day ...
    finished drilling all the damn tedious safety wire holes today... (a few examples)
    effing motard with a hydraulic clutch... wtf??? had to drill and wire the slave cylinder.
    what is wrong with a basic cable???? And why the fuck do these things have to have 2
    oil filters and 2 oil screens????
    a beautiful example of cut safety wire on an exhaust bolt... with out the exhaust...
    completely out of focus for your viewing enjoyment.
    and after all that KB mounted my new rubber for me...
    and with that i am damn close to done... just need to re-fill with fluids, add the catch can(s), alter some wiring, reassemble, and get the freshly drilled holes filled with safety wire.
    oh and at some point i am gonna need to track down PK to get the initial basic suspension settings adjusted.
    Brent LRRS #772
    2006 KTM 560 SMR
    Mar 2002
    Amherst, NH
    race bike prep...
    oh yea... the street legal (titled in nh) yz450f to the rear left of the race bike might be up for sale... for the right price.
    Brent LRRS #772
    2006 KTM 560 SMR
    race bike prep...
    ... is that front tire mounted in the right direction? Pattern looks opposite to rear.
    Lifer smf's Avatar
    Nov 2006
    race bike prep...
    nice i just finished up 4 hours of wrenching on mine. only thing left to do is mount the tank, mount tires and check all the bolts... oh and make sure the jetting is at least close.
    and that front tire does look odd.
    Scott
    Dec 2003
    Ma
    race bike prep...
    I see a few motards there, is the little miss racing too?
    Who's going to be running the same races for NESR, seems like there'll be quite a few of you in the tard race.
    Mar 2002
    Amherst, NH
    race bike prep...
    she'll be doing a few races here and there.
    we both sold our big street bikes... the motards are our only streetable bikes now.
    Brent LRRS #772
    2006 KTM 560 SMR
    Mar 2002
    Amherst, NH
    race bike prep...
    you got me paranoid. so i just went and checked... and they are mounted with the little arrows pointing the right way.
    maybe michelin cut the grooves backwards?
    Brent LRRS #772
    2006 KTM 560 SMR
    race bike prep...
    When did you get a KTM?
    Savannah, GA
    race bike prep...
    u safety wired the banjo bolts? didnt know you had to. ?
    race bike prep...
    you don't. Banjo bolts are the exception to the "holds back fluid" rule.
    race bike prep...
    Don't forget to lay the bike on it's side when you change those two oil filters and prefill the filters
    Apr 2006
    Beverly, MA
    race bike prep...
    If you sold the YZ, what would you want for it? Can you PM me more pics of it?
    Thanks!
    race bike prep...
    Quote Originally Posted by The Magician View Post
    There are severaly things you don't "have" to wire... but should.
    Besides banjo bolts, consider the bolts that hold brake and clutch levers.
    Also, do your shifter rod and all bolts associated with that. (I have seen countless DNF's due to shifters)
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Mar 2002
    Amherst, NH
    race bike prep...
    Forgetta bout it!
    I stumbled across a sweet deal with Nates help over the winter and decided to upgrade, especially after having ridden a few other KTM's.
    I did wire some banjo bolts... then i re-read the rules more carfeully when i was scrutinizing for things i may have missed and realized i didn't have to. no biggy. just a little bit of extra insurance.
    i hadn't considered the shifter and lever bolts... thanks for the tip tony.
    Brent LRRS #772
    2006 KTM 560 SMR
    Mar 2002
    Amherst, NH
    race bike prep...
    ummm i broke the links by accident. and the edit button is missing.
    so if anyone cares about the pics... check the photo album out...
    http://smg.photobucket.com/albums/v722/oreo_n2/KTM/
    Brent LRRS #772
    2006 KTM 560 SMR
    race bike prep...
    Quote Originally Posted by oreo_n2 View Post
    hah, those crazy groove gremlins, always skrewin around, fukin shit up.
    Mar 2002
    Amherst, NH
    race bike prep...
    Well...
    Catch cans installed.
    DOT's mounted.
    Body reassembled
    Water and water wetter installed.
    Oil in the case
    Street wiring removed
    Safety wired all the damn holes i drilled.
    ran it around my condo complex for a few laps...
    Dare i say... i think its ready for the track.
    Find out for certain tomorrow at Tony's Track day.
    Brent LRRS #772
    2006 KTM 560 SMR
    race bike prep...
    Oh great... use us as the "test bed"
    Seriously... if anyone has done any kind of work to their bikes, I strongly encourage early morning rides around the OUTER PIT AREA just after tech and before you get on the track.
    DO NOT SPEED. Just first or barely into second gear. You really just want to get the engine up to full temp.
    By OUTER PIT AREA, I mean well away from the garage area. Remember, the ENTIRE PIT AREA has speed limit of 15mph
    Tony
    Mar 2002
    Amherst, NH
    race bike prep...
    Tony, i'd be honored if you gave the bike your own personal safety inspection to make sure its in tip top shape for use at your track day!
    Brent LRRS #772
    2006 KTM 560 SMR
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    race bike prep...
    Braaaappp!
    This is gonna be lots of fun bro. Do I see that Joel is going to make this one too?
    Haverhill, MA
    race bike prep...
    KB KB's Avatar
    Manchester NH
    race bike prep...
    Tony make sure you check the owner for a "few loose screws"!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    race bike prep...
    and check the tightness of his nuts
  1. Race prep.
    By Johnpewpew in forum General Bike Related
    Last Post: 08-03-17, 08:57 AM
  2. 2002 SV650 Race Prep Track Bike - $2400
    By Loun in forum For Sale
    Last Post: 05-12-11, 01:39 PM
  3. race prep
    By woody9189 in forum Pit Area
    Last Post: 02-17-10, 07:09 AM
  4. Race prep Bike for Rookie race?
    By CMG241 in forum Pit Area
    Last Post: 04-20-08, 06:16 AM
  5. race bike prep/ day 1
    By GMS1000 in forum Pit Area
    Last Post: 01-31-03, 09:55 PM
