Results 1 to 23 of 23
rear brake
    Registered Boozer PPS26's Avatar
    May 2007
    haverhill ma
    rear brake
    who uses it while racing?? i know like 4 riders who use it just curious who else uses it???
    Plaistow Powersports Racing
    Lrrs/ccs/ahrma EX #26
    Wait, what? Jonny Rocket's Avatar
    South Windsor, CT
    Re: rear brake
    I use it.
    Nov 2007
    Re: rear brake
    I have heard a lot of the motard guys say they drag it to keep the front settled especially in 9 and when driving out of turns to keep the line tight
    I personally don't use it on either bike but I've never really felt comfortable enough to try
    Zip-Tie Alley Racing
    LRRS/CCS #103
    May 2007
    haverhill ma
    Re: rear brake
    rick b (#28) keept telling me to try it while i was on the rmz.. i never wanted to, one time i tried it going into 9 and i was so worried about making it work that it messed me up all together and i never tried it again
    Lifer Pittenger5's Avatar
    Austin
    Re: rear brake
    Rick Breen just looks at the rear brake and scares it into submission.
    I dont. Wish I did when my brake pads fell out.
    Zip Tie Alley #505
    Re: rear brake
    slow down to practice it til it becomes natural, then pick up the pace again.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: rear brake
    I use em
    Lifer obsolete's Avatar
    Norf Sho
    Re: rear brake
    His rear brake benches more than us.
    -Alex
    Re: rear brake
    Not I.
    I'm still improving as it is without it. But as I know of it's benefits, if/when I plateau I'll probably begin experimenting with it in practice and try to incorporate it into my bag-o-tricks... but until then I'll likely leave it alone.
    ....... Nazo's Avatar
    Jul 2004
    Re: rear brake
    Rear brake is beneficial once your really going into the turns deep on the gas and need to shed more speed in a shorter distance....way beyond where my riding skill is.
    I find that if I do use it sometimes going into T3 it will help settle the rear tire (or at least it feels like it does)
    If your going to start using your rear brake its a good idea to put an air bubble in the brake line so that its not so touchy and you won't lock up the rear brake.
    Chris
    LRRS Expert #160
    Re: rear brake
    My twin is my rear brake.
    Just Registered Doc's Avatar
    Jericho, VT
    Re: rear brake
    The only time I use it is when i go off the track.
    Re: rear brake
    There are brakes on these things?
    Re: rear brake
    I can't use the brake when the tire is floating above the ground.
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    Re: rear brake
    It's mostly useful for getting the rear to squat a bit, which settles the bike. It also stabilizes the bike by essentially "pulling" the rear of the bike to keep it in line with the front tire (let's hope the front tire is pointed where you want it )
    To do this requires that you apply the rear brake just before the front brake, then ease off of it as you brake harder with the front. Sound complicated? It is. Which is why I generally don't use the rear brake.
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Re: rear brake
    I use it on both motard and normal bike.
    Boston --> San Diego
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: rear brake
    I use it ocassionally, my foots always in position to, but with the slipper, have used it less than when i wasn't on a slipper.
    oh - and when my front brakes fail (only once down into the bowl).
    KB KB's Avatar
    Manchester NH
    Re: rear brake
    Where is the rear brake again?
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Central MA
    Re: rear brake
    Curious... can you help me understand how having a slipper effects use of the rear brake?
    Posting Freak Scottg22's Avatar
    NH
    Re: rear brake
    That thing is voodo! Danger stay away!
    Seriously. I have NEVER bought a set of rear brake pads in my life.
    May 2007
    haverhill ma
    Re: rear brake
    rick said that about u scotty i was wondering if it was true
    Lake Champlain, VT
    Re: rear brake
    Quote Originally Posted by FirstLightning View Post
    I can drop a couple gears and not break the rear loose with engine braking... When the rear would skip, i'd use the rear to settle it.
    Re: rear brake
    Quote Originally Posted by Scottg22 View Post
    I'm with you scotty! Not sayin it can't be used, but is it really doing anything to improve laptimes??? Highly doubtful.
  1. Rear Brake Help
    By throttlejunkie in forum Bike Maintenance
    Last Post: 08-18-12, 10:07 PM
  2. The rear brake
    By -jro- in forum General Bike Related
    Last Post: 06-05-08, 04:58 PM
  3. rear brake pedal/rear light not working
    By seth399 in forum Bike Maintenance
    Last Post: 04-10-08, 09:57 PM
  4. Sticking rear brake
    By TegRacer324 in forum General Bike Related
    Last Post: 02-18-08, 08:30 PM
  5. rear brake
    Last Post: 10-01-04, 06:40 PM
