Keep the damper and use it for trackdays
Sell the damper and use the money for trackdays
Sell the damper and find one that works with the stock plastics
So I know there are a few people here who race 600rr's and I have a general question. Do you feel that the 600rr needs a Steering Dampner on the track?
A little history: I bought a 600rr race bike that I am converting to a Street bike/ Track day bike and it came with an Ohlin's fork mounted Steering Damper. I had to take the damper off in order to put the stock Fairing back on and my options are listed in the poll.
Whats the issue with the plastics and the damper?
Unless you are REALLY hustleing the bike I don't think you need a damper.
Keep tha damper dude
Whether you need it or not would also depend on the suspension set up you have. If you've dropped the front forks a little the bike could get twitchy - the damper could help.
SSearchVT
You will need the damper, better rider have tried and failed to ride with out one. It's not a speed issue, but rather one of stability. Keep the damper, it can be made to work with the stock bracket, unless you like broken collar bones and ground off fingers.......
Hmm collar bone has been broken once and I would like to avoid that again. That is basically what I figured but I was hoping I might be able to justify selling it. The Damper is not an issue with the track plastics, just does not fit with the street plastics. I will keep it and re-install it for the track days.
Thanks Again,
Randy
or sell the Ohlins and get a Scotts which does work with
stock plastics.
Anyway whats the conflict with the Ohlins and the stock plastics
anyway? Just get out the hack saw !
i race without a damper. you could take it off and try a trackday without it and if you get the shiggles then put it back on
Trade it for a scotts or GPR or adjust the street plastics to fit.
My 2 cents...
Make it work, or sell it and use the money to replace it.
As Pete (GMD) mentioned, others have proven the danger of not having one. Why not benefit from their pain?
And I'm not sure I can agree with the "try it without and if it shakes, get one" method.
Kind of like telling a teenager...
try sex without a condom, and if she gets pregnant, then use one next time.
My point being that the first "shake" may be your last.
After hustling a 2004 CBR600RR (no damper) around VIR for two days I would recommend keeping it. I had a few nasty bouts of headshake.
Boston --> San Diego
Dampers are cheap insurance for track days, and make you a lot more confident in your bike. I bought one for my R1, rode it on the track the one day without it, and installed it the following day, and swore I'd never own another sportbike without one.
about dampers...
question for ya:
I just got mine installed (a Scotts on my 600RR)
Its set right now pretty close to wide open.
Are you supposed to feel its effect just riding around?
I dont even notice it.
How do you know when its adjusted right aside from riding fast
at the track and getting headshake?
You should only feel it when you need it right?
-Akira
Turn it to about half of it's resistance setting. Now try to turn the bars slowly. You should feel a little resistance. Now try to turn the bars fast and you will feel more resistance.
I usually run mine pretty low for the street and turn up the resistance for the track, to the point where I feel some resistance riding around the pits, but not enough that steering is difficult.
derek
I keep mine set pretty low. I don't mind feeling a little shake it let's me know I'm at a fast pace, but it will stop the bars from slamming around. I have a GPR and set it at about 2 or 2.5 out of 6 for racing.
Thanks
So I see its not a rocket science...
which is good since I'm not a rocket scientist !
Thanks Everybody and to Akira for asking my next question for me.
