This is the weekend you racers and race fans long for all season. In a nutshell, it's going to be a beautiful weekend with Fri, Sat, Sun all being pretty much the same although temps will slowly rise a bit higher each day.
Once the clouds and fog burn off this morning, look for mostly sunny skies with temps topping out in the mid- to upper 70's. From there, it'll be mostly bright sunshine for the rest of the weekend. Typical seasonal summer humidity will climb each day during the daylight hours, but dew points will remain relatively low. The only thing that will change is the temps. It'll gradually get a bit warmer each day throughout the weekend.
Friday: Temps in the mid- to upper 70's. Nighttime temps dipping down to the low- to mid 50's.
Saturday: Temps will climb a bit higher into the low 80's with night temps still in the lower 50's.
Sunday. Temps will still be climbing into the mid- to upper 80's, while nighttime temps will start regulating in the upper 50's to lower 60's.
It's not usually wise to plan on weather outlooks more than a couple days in advance around here. But if you're looking to extend your NH stay and poke around for an extra day or two, it's looking like Monday & Tuesday will continue the trend of mostly sunny skies with temps getting into the mid- to upper 80's while dew points remain relatively low.
