Results 1 to 25 of 32
Safety wiring
    Lifer gixxer72's Avatar
    The desert
    Safety wiring
    OK, so I now have a drill press, vice, some 1/16" cobalt bits and a supply of adult beverages. Planning to get started putting holes in fasteners tonight on the race bike (K7 600). I am drilling:
    Caliper bolts
    Oil Drain plug
    Oil Fill cap
    Axle pinch bolts
    This list seems too short (I'll wire the oil filter, hitch pin on rear axle, grips later on).
    What else do I need to / should I wire up? Thanks
    Lifer Pittenger5's Avatar
    Austin
    Re: Safety wiring
    Anything that holds back any liquid, and anything you dont want falling off in the middle of a race.
    Zip Tie Alley #505
    Re: Safety wiring
    Put a Big Hoseclamp on the oil filter And run a wire from the clam to the Frame.
    Radiator Fill cap, And Water pump drain bolt.
    Header Bolts?
    Muffler Bolt?
    Axle Bolts?
    Check the Rulebook It should be online.
    Or PM Senacake or someone else who raced the same bike and ask them, Kitt would be a good resource as well.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Re: Safety wiring
    Exhaust bolts, exhaust clamp and mount
    Axles and nuts
    Radiator cap
    All banjo bolts
    Re: Safety wiring
    what about radiator & reservoir caps? i know you guys dont safety wire your brake res caps.
    The desert
    Re: Safety wiring
    OK, maybe a stupid question but would this include the banjo bolts on your brake lines (OK to drill through those?)? I assume any oil lines that are bolted on is a good idea, what about things like clamps on radiator hoses, are those typically wired up? My current race bike seems to have just the bare minimum done so I guess I am wondering what's overkill, or any specific items in addition to what I listed above are needed. Thanks
    Just saw the banjos listed, thanks Kurlon.
    Re: Safety wiring
    Quote Originally Posted by DBKromz View Post
    I don't safety wire my brake res, but I do wrap it with a sweat band which is zipty'd in place to act as a diaper should it start to leak.
    Oct 2005
    Wrentham MA
    Re: Safety wiring
    Caliper bolts
    Oil Drain plug
    Oil Fill cap
    Axle pinch bolts
    1/16' bits
    Hope some = lots. those little suckers snap easy.
    Exhaust fasteners....(bolts attached to frame/motor that stop exhaust parts from falling off), you should also safety wire any fluid hoses/connections such as coolant. Basically - anything if fluids come out it can get on your tires or spray backwards.
    LRRS mandated a few years back the pin that holds the brake pads in be wires - normally just a little clip is on there.... basically to stop the pin falling out if the retaining clips goes...not sure they are still checking for that - but it IS a huge advantage to not have your pads fall out.
    Oh and only water with water wetter added at the correct ratio is allowed. (not engine ice etc). Some anal nerd sometime checks coolant....me
    Graham
    Meriden, Ct
    Re: Safety wiring
    No one likes an anal nerd...
    Oct 2005
    Wrentham MA
    Re: Safety wiring
    THe bottom line -
    for tech - if you are a novice be prepared to be looked at very carefully.
    for saftey - anything you feel could be a big problem coming loose.
    Graham
    Lifer Fitz's Avatar
    New Boston, NH
    Re: Safety wiring
    Quote Originally Posted by xsiliconkid View Post
    It makes sense but somehow I missed that for 2008 & 2009. Any recommendations on how to go about doing this?
    Thanks!
    Fitz
    Junior Member VT-GSD's Avatar
    South Londonderry, VT
    Re: Safety wiring
    Hi first post here. I am starting this process as well on my k6 750, got most of the stuff done. Where I get lost is on the fluid hoses. Is it safety wire around the hose itself and back to something or safety wire the clamp together so it cant open?
    Also on the banjo bolts I printed the rule book and looking in the safety wire section it says "it is not advisable to wire hydraulic lines or banjo bolts"
    So ???
    Thank you.
    Oct 2005
    Wrentham MA
    Re: Safety wiring
    BE VERY CAREFUL with what you do around the brake res cap!
    As we all know there is a diaphragm above the fluid separating the atmosphere from fluid.... allows for expansion and contraction of the fluid due to
    - heat (water vapor that WILL build up in the fluid)
    - pad wear
    In the cap, normally on the side, there is a very small vent hole to let atmospheric pressure sit on top of the diaphragm... block this and you can end up with Hydraulic lock on the brakes - for some reason this happens in T7-8. I
    have post crash looked at two bikes that crashed there - they had tape around the brake res cap and said all off a sudden front brake just LOCKED UP.
    Graham
    Austin
    Re: Safety wiring
    Turn 11 hurts when your brake pad falls out ... trust me.
    Zip Tie Alley #505
    Austin
    Re: Safety wiring
    Also happened to me between 6-7.
    So the moral of the story is, anything DB does, dont do.
    Zip Tie Alley #505
    Re: Safety wiring
    Me to, No tape involved
    Re: Safety wiring
    engine ice isnt allowed for racing?
    Oct 2005
    Wrentham MA
    Re: Safety wiring
    I tend to agree....
    but a many-bike-pile-up in T7 this past season due to someone dumping antifreeze is probably worse - ...hence starting to ask the question and random checking ( with a very quick 100% reliable test) in tech --- you would be surprised (or maybe not) how many folks had antifreeze, and in one case 100% water wetter.... doh!
    while I hated to do it - they were turned away from tech until fixed-most understood.
    And again engine ice is antifreeze -it is allowed in a couple of other US race series...hmmm they also were a sponsor of that series...
    We did test engine ice and it's as slippery as the old antifreeze..... anything with glycol is a problem
    -Propylene Glycol may be non toxic but it is slippery
    - Ethylene Glycol also just happens to be sweet, toxic, and deadly
    BTW I would not recommend drinking either - for a while after testing I did not drink anything at the track that had green, red or purple coloring
    Graham
    Oct 2005
    Wrentham MA
    Re: Safety wiring
    Quote Originally Posted by VT-GSD View Post
    So ???
    Thank you.
    Correct safety wire stops unwinding of bolts etc not the just coming loose. Less then a 1/8 turn on the banjo bolts and you have already lost your hydraulics...on the other hand with oil lines.... it is better to stop oil pouring out faster.:
    I wire around the clamp bolt to the frame so it can't loosen
    Graham
    Oct 2005
    Wrentham MA
    Re: Safety wiring
    Quote Originally Posted by Fitz View Post
    Thanks!
    Fitz
    the quickest way to explain is with a photo - will post one shortly as to the easiest way to do it.
    Graham
    Re: Safety wiring
    Thank you xsiliconkid. That is kind of what I was thinking.
    now I can continue getting ready for my first race few more things and I think I am ready to go.
    Alex
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Safety wiring
    decent write up here http://www.rc51.org/wire1.htm
    doesn't show hoses being wired though.
    Oct 2005
    Wrentham MA
    Re: Safety wiring
    Thanks!
    Fitz
    I just wire around the pin (on inside of caliper) and then loop to the outside and around the outside of the pin....all you are doing is stopping the pin from extracting, should the small clip come out (they are very weak and lose tension over time and do fall out).
    see pic for how to
    You only need to do one pin per per pad set.
    the other way is to drill the flat spot on the pad retaining pin - but first you need to grind off the case hardening - this is pain (or purchase predilled pins) and wire to the calipers.
    Graham
    Bridgewater, MA
    Re: Safety wiring
    and for the pad pins http://www.probolt-usa.com/Products/...liper_Pad_Pins
    been meaning to order a set myself
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Safety wiring
    After I go thru tech I remove the brake pads, levers, cables, and foot lever. Saves me thirty pounds.
  1. Safety wiring question
    By MaRce1o in forum Pit Area
    Last Post: 04-03-17, 05:33 PM
  2. Safety Wiring Saturday 8/22
    By CEO in forum Pit Area
    Last Post: 08-26-08, 11:01 PM
  3. Safety wiring for Dummies
    By Doc in forum Pit Area
    Last Post: 04-16-08, 06:36 AM
  4. Safety wiring a bike
    By xxdcmast in forum Pit Area
    Last Post: 10-18-07, 01:49 PM
  5. safety wiring
    By oreo_n2 in forum Pit Area
    Last Post: 03-28-07, 10:06 AM
