Results 1 to 22 of 22
Safty Wire
    JACKASS hammadown's Avatar
    Hopkinton, MA
    Safty Wire
    Anyone know a place around greater boston that has Safety wire? Ive tried a few dealerships, but none of them carry it.
    Zip Tie Alley #237
    Lifer eboos's Avatar
    Re: Safty Wire
    Motorsports International in Auburn (just south of Worster) has it in stock.
    Lifer Pittenger5's Avatar
    Austin
    Re: Safty Wire
    How much do you need? And more importantly when do you need it?
    Ill be at the garage sometime friday night I have enough.
    Zip Tie Alley #505
    Hopkinton, MA
    Re: Safty Wire
    Thanks for the offer. I need to do 2 bikes, and a third down the road, so I figure Ill just get a roll. I want to do some work on them at the track since its the only time I seem to have to work on them. Unfortunately there will be no racing for me this weekend
    Zip Tie Alley #237
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    Re: Safty Wire
    If you get stuck you could swing by tonight and borrow a can from one of us.
    Are you practicing?
    2003 R6 - Track
    2000 SV650 - Street/Track
    Austin
    Re: Safty Wire
    Cripes, you and Dan are leaving it up to Wookie and me to carry garage #whatever garage number we're in the torch.
    Oh and of course our temporary guest, but he doesnt count, hes like a spy
    But like I say I think I have 2 rolls of different thickness flying around, so if you need any and cant get your hands on some Ill have it up at the track.
    Zip Tie Alley #505
    Foxboro, MA
    Re: Safty Wire
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Just Registered kermita's Avatar
    Mar 2007
    RI
    Re: Safty Wire
    Quote Originally Posted by hammadown View Post
    We've got a 1lb can of .032 safety wire in stock. If you're going to be at the track on Sunday, Monday or Tuesday I can deliver it for you.
    Speaking of safety wire...what do you guys use for drill bits? I find that the cobalt ones I've used work for a minute or so then stop doing much of anything. Is there a brand that holds up better than others?
    -kim
    drz400sm
    http://farm3.static.flickr.com/2473/3532494258_79ceb54614.jpg
    Re: Safty Wire
    Street and Comp
    At the track
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Re: Safty Wire
    [QUOTE=kermita;487432
    Speaking of safety wire...what do you guys use for drill bits? I find that the cobalt ones I've used work for a minute or so then stop doing much of anything. Is there a brand that holds up better than others?[/QUOTE]
    Harbor freight about 20 Cents each, More quanity then quality will get it done as well
    Savannah, GA
    Re: Safty Wire
    yiou gotta constantly use oil... otherwise they are no good. i think i did a whole bike with 3 drill bits the first time i ever did it lol... with cheapy bits too.
    Mar 2007
    RI
    Re: Safty Wire
    Quote Originally Posted by The Magician View Post
    cool...what kind of oil?
    -kim
    drz400sm
    Re: Safty Wire
    My friend advised I thouch the face of any bolt/hardware I am going to drill with a file or grinder first, removing the hardened surface so the drill doesn't have to go through it before getting to the easier drilling material underneath.
    Austin
    Re: Safty Wire
    Another trick I learned, and Im not sure how to explain it well, is try to have the bit the shortest you can so it doesnt start wobbling and flexing as much, like have the drill end RIGHT up to the cutting part of the bit. Its still long enough to get through, but you dont have a lot of excess to get it flexing.
    Zip Tie Alley #505
    Mar 2007
    RI
    Re: Safty Wire
    Thanks for the suggestions guys.
    -kim
    drz400sm
    Foxboro, MA
    Re: Safty Wire
    a vice, drill press, or at least a corded drill
    2006 Yamaha R6
    Austin
    Re: Safty Wire
    Quote Originally Posted by Denno View Post
    Zip Tie Alley #505
    Foxboro, MA
    Re: Safty Wire
    what time are you arriving? fri practice?
    2006 Yamaha R6
    Austin
    Re: Safty Wire
    Nah I wont be up till friday night.
    Zip Tie Alley #505
    Foxboro, MA
    Re: Safty Wire
    see you in the pm then
    2006 Yamaha R6
    Austin
    Re: Safty Wire
    Quite so sir
    Zip Tie Alley #505
    Posting Freak boloson's Avatar
    Oct 2007
    Re: Safty Wire
    brocton cycles has safety wires in stock on 1 of them middle racks last time i went there in january
  1. Safety Wire Your Safety Wire
    By Jim in forum Bike Maintenance
    Last Post: 12-02-09, 03:21 PM
  2. Safety wire ??
    By Half Squid in forum Pit Area
    Last Post: 04-05-07, 11:50 PM
  3. Safty wire questions?
    By R7 in forum Pit Area
    Last Post: 09-12-03, 10:11 PM
  4. safty rules?
    Last Post: 09-10-03, 12:28 PM
