Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
ultra light class and 1999 sv650 question ??
    Wirelessly posted (GS3)
    You can sleeve down an SV to a 500 to run in ulsb.
    Re: ultra light class and 1999 sv650 question ??
    Nope, you get hung up by the rule that says you can't downsize a machine to fit a lower class. That's not the trick.
    Edit: This triggered a few memories... *IF* you could swing a 98 SV400 frame... At least one LRRS celebrity has looked into this path that I know of.
    There *IS* a way to run an SV in ULSB, punched out even...
    You wouldn't be referring to the SV400 would you?
    Nope, although as written a 1998 SV400 is an alternate path, but you've got to have a 1998 SV400 frame.
    May 2013
    Epsom, NH
    Hmm this is interesting...
    Are you talking about putting an SV650 motor into an SV400 frame? Clearly it wouldn't be SS legal but is that still allowable for SB? Maybe someone with faster internet than me can look up the technical part of that in the rule book. lol And even if you bored out the 400 to 2mm or 3mm over it only add around 20cc's at most? Then again it'd still be SV400.. Not sure still how you'd get an SV650 into ULSS/SB with out like someone else said someone not noticing?
    Has anyone run a "1998" SV400 in either ULSS or ULSB before and would it even be competitive enough in the UL class to even bother? I'd assume if nearly all the components were compatible with the 650 then it could have at least some potential.
    When the hell did they ever make an SV400? Never even heard of it.
    Hiram, ME
    Were you even alive in 1998?
    (for the record, I'd never heard of an SV400 either, and I know what year Smutty was born; I just like the occasional chance to make fun of him for being one of those damn kids I want off my lawn)
    5 Not allowed! Not allowed!
    http://www.suzukicycles.org/SV-serie...0-SV400S.shtml
    It wasn't brought over here.
    Although, like my Fizzer a few were imported, at least two complete ones that I can document.
    What do the rules say about a motorcycle that was produced outside the US?
    For Superbike, there is no restriction that it had to be produced in / for the US market.
    Quote Originally Posted by 2014 LRRS Rulebook
    20.2 SUPERBIKE - SuperBikes are based upon production
    models, sold by manufacturer and their dealers anywhere
    in the world for street use via normal commercial
    channels. Proof of compliance rests with the competitor
    entering the motorcycle. All machines must have
    unaltered VIN numbers. CCS reserves the right to
    declare unusual or limited production machines eligible
    for SuperBike competition. All machines must meet the
    standards of Section 19 as well as the following. CCS
    reserves the right to re-factor machines at any time. CCS
    will notify current licensees 30 days prior to any change.
    Changes will take effect 30 days from the original date of
    notification.
    My model FZR was only produced for Japan, but was sold as a street bike and thus can be run in SB. You're likely thinking SS which requires the machine have been sold for street use in North America.
    Interesting.
    Can you run a custom/bastard build?
    Examples:
    1) your own frame
    2) let's say gsxr frame, Yamaha motor (any combination similar)
    3) different class frame - lower class motor such as let's say SV1000 frame with SV650 motor
    Don't have to answer any of these Josh I'm just curious.
    1) Your own frame - Nope, gotta be from a production machine sold for street use somewhere in the world to be in SB. You CAN however fab your own frame if you want to run GP classes.
    2) Yes, with the proviso that you don't mod the engine mounts or other key points on the frame as per the SB rules. Mod those points, you're stuck in GP again. One other gotcha, noted for example 3 applies here too.
    3) The frame determines the class eligibility, and you can't downsize from there. If you start with an SV1000 frame, you've got a 4v per cylinder liquid twin based chassis, HWSB is the lowest class it can ever be eligible for. Hence why a 1998 SV400 frame is magic, it meets the rules for ULSB, hang any ULSB legal motor build (800cc SV?) you want in there AS LONG AS YOU DON'T MOD THE SPECIFIED FRAME POINTS to do it. Again, GP rules toss this right out the window, mod the frame, downsize, whatever, GP classing is based entirely on engine setup alone. This is why you're seeing de-stroked GSX-R 600s running LWGP in Florida now. Unfortunately as built they are two class bikes, LWGP and GTL and that's it.
    Edit: Single Cylinder Blind Spot makes this all moot. Take a Panagale, lop a cylinder off and it's ULSB legal.
    I'd heard insanity was contagious, perhaps this is why your ideas are starting to make sense. I'm still gettin' whupped by stock SV's however, so perhaps I could use a box of Spanish hand-built riding skill...
    May 2013
    Epsom, NH
    If you can't modify the engine mounts on the frame can you modify the engine block to mount where the frame mounts are located? Or is there no modification allowed at all to prevent engines that were not meant for that frame to be used? I know blocks being cast it would be much more difficult to do any modification but not entirely impossible
    SV400s are built for ulsb all the time by companies like spears and twf. Im not sure if they sleeve down or replace jugs. As I see it, its the same as running the gsxr450 3 cyl bikes people make out of gsxr600s.
    I forget what the displacement limits are for liquid cooled twins made after 98 but I thought it was 500 since EXs are allowed.
    if PT was still a class you could run a SV500 in that as well.
    Outside of LRRS you don't need to sleeve down an SV650 to run ULSB. Inside of LRRS, sleeving down won't make it ULSB legal, you've got to start with a 98 SV400 frame.
    Now sleeving down for WERA, that works, just like they allow the GSXR450s that CCS won't outside of LWGP.
    ULSB allows liquid twins up to 650cc, pre 99 model year, non desmo you can go to 800cc. LRRS puts a cap on liquid twins in ULSB that they must be 98 or earlier. I'd say EX500s get snuck in under a like machine allowance even after 98.
    A sleeved to SV500 wouldn't ever be legal for PTwins, an SV400 in stock trim wouldn't have been either because it wasn't sold in the US.
  1. For Sale - Motorcycles | 1999 SV650
    By nhbubba in forum For Sale
    Last Post: 06-12-23, 09:09 PM
  2. Wanted - Parts & Tools | SV650 TAIL LIGHT 1ST GEN
    By smokinjoe in forum Wanted
    Last Post: 05-27-15, 06:29 PM
  3. Wanted - Parts & Tools | WTB: 1999 to 2002 SV650 CDI box
    By Viper897 in forum Wanted
    Last Post: 10-03-14, 09:20 AM
  4. MARCHESINI-ULTRA LIGHT WHEELS
    By BigShel in forum General Bike Related
    Last Post: 03-13-06, 06:54 PM
  5. LRRS Am class question
    By sandhammer in forum Pit Area
    Last Post: 08-02-03, 03:14 PM
