Anyone got a spare?
I have a stock Suzuki one, but apparently my new aftermarket master cylinder has a slightly smaller diameter connector. Anyone got one that would work for an Accossato master cylinder? One for a Brembo m/c would probably do the trick.
I'm not about to go spend 60 frikkin bucks on THIS.
I'll work a trade if you want a stock one.
What eboos said. 1/4" tubing will easily stretch over the reservoir fitting.
10-4. After some quick research I ordered a couple feet of this in .25" inner diameter - Tygon 2075
.25" = 6.35mm. Hopefully it'll stretch out to about 3/8" or 10mm on the reservoir side.
I already have some similar tubing but the ID is to wide.
If life gives you lemons... Sue the motherfu**er!
One tip to tubing stretching is to use a hammer to soften up the end you want to stretch. It will warm up quickly and expand.
HEY..PAY ATTENTION, Chuck....In 2 weeks you'll be asking what is the best one for your bike is![]()
I just bought a Brembo RCS 19 and I'm figuring out what to do for a reservoir/tubing. I'm happy to hear the 6mm tygon will stretch over the 8mm stock outlet on my SV650 reservoir, but the stocker is kinda faded so I might just buy a Brembo universal reservoir for like $15. If I buy one, which capacity should I go with (15, 30, or 45 mL)? I was leaning towards the 30..
