Results 1 to 14 of 14
Dropped bolt
    Posting Freak
    Dec 2009
    Dropped bolt
    When working on the controls I typically put a rag around the front of the tank to keep dropped things from disappearing. Today while fitting a Ram ball mount to the top triple I didn't. Perhaps it was the heat in the garage or laziness. Hard to believe that stud could make it through the space between the front of the fuel tank and frame on its way down who knows where.
    Re: Dropped bolt
    Got a mechanic’s magnet?
    Arlington MA 02474
    Re: Dropped bolt
    For me it's usually the stainless steel hardware that drops into some dark crevice. Sometimes the bits shake out a year or two later.
    Re: Dropped bolt
    This is up there with loosing all of your 10mm sockets; just about everyone has been there, got the t-shirt.
    My magnet-on-a-stick gets a lot of use.
    I'll add that now that I have a lift table dropped hardware doesn't seem to go quite as far as it used to. Up-side to the rolled up, sharp as a razor edges on my cheapo HF lift I guess.
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Dropped bolt
    I have a smart phone TV probe like an endiscope, then sticky tape
    There still is a 14mm in the dash of my Civic
    The calculus of hate
    Posting Freak
    Dec 2009
    Re: Dropped bolt
    Raised the front of the tank and mechanics magnet to the rescue. On the plus side I found a couple more screws the prevoius owner had lost!
    Re: Dropped bolt
    1985 I’m doing a cr125 top end. Brought home 2 piston clips. First one goes on piston in my hand like it should. Putting second one on it goes across the garage. Pings off something metal across the garage never to be found but at least not in the engine. Next day I bring home a whole packet of clips. Of course having extras means the clip went on perfect the first time. I hate dropping and looking for stuff. The lift sure does help like mentioned helps. I glued some hot water pipe insulating foam on the corners to save my shins when it’s in a lowered position.
    Re: Dropped bolt
    I hear a track day is a good way to shake out those loose fasteners. Lol.
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Dropped bolt
    "dropped bolt" or, "how to make a quick 15 minute project drag out over an hour"
    Re: Dropped bolt
    Somewhere at Palmer is a 4mm rubber Well Nut with brass insert.....
    Posting Freak
    Dec 2009
    Re: Dropped bolt
    I seem to be getting more of those lately.
    Re: Dropped bolt
    Quote Originally Posted by 02redhawk View Post
    Absolutely guaranteed that if you drop a bolt, you will have two spares: one too short, one too long.....
    Central Maine
    Re: Dropped bolt
    Last time it happened to me, I just wanted to top off the coolant on the grizzly atv. Like flip top lid, put coolant in, snap it shut.... but the lid came all the way off and fell in the skid plates. Now I have the jack out, a flashlight, im lying on the ground, start removing rusty skid plate bolts....
    Lifer capitalcrew's Avatar
    Feb 2017
    Albany NY
    Re: Dropped bolt
    Too long is an easy fix.
    Too short not so much
  1. lap times dropped
    By sprinkler_1 in forum Penguin School
    Last Post: 10-08-12, 05:44 PM
  2. DROPPED MY HELMET!
    By PMPDVL in forum General Bike Related
    Last Post: 07-18-07, 02:23 PM
  3. Damnit - Dropped Duc
    By LuvDog in forum General Bike Related
    Last Post: 06-18-07, 08:20 PM
  4. Just dropped in from NH
    By Zorlock in forum Welcome and Intro
    Last Post: 07-18-04, 06:53 AM
