Results 1 to 12 of 12
Chain recomendations!
    Pelham, NH
    Hey guys,
    the RF900 has just clocked 12k on what i must presume is the original chain (i am the second owner)
    what do you guys recomend for a replacement? what lube do you use? would you recomend changing the sprockets out at the same time?
    cheers
    Bloke
    Immigrant from the UK
    1998 VFR800
    AIM Blokegst
    Replaced the original chain on my RF at 18,000 miles. Went with the 520 conversion (steel sprockets) and used NOTHING but chain wax on it. Got 25,000 miles outta that chain/sprocket set-up too. Coulda gotten more if I hadn't wadded the thing!
    Oh, and YES. Nothing'll ruin a new chain quicker than old sprockets. As a general rule of thumb, when your chain is worn out, your sprockets are too...
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    I'd go D.I.D. 520 conversion (Gold..... hi-tensile). Use rivet type master. I would also run Renthal, AFAM or Sunstar sprockets (steel front). For chain lube, I use BelRay wax.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Originally posted by Rye
    For lube, I use BrownStar wax.
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Nya Nya Nya.......I kill you last!
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Check your PM's, slittleicous...
    DID ERV-2 Gold 520
    derek
    Walpole
    What Degs said. Use AFAM sprockets too.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Pelham, NH
    thanks a lot guys, truely appreciate it, even your advice Stoneman!
    1998 VFR800
    AIM Blokegst
    Gone Fishin' trackdog's Avatar
    Was considering a 520 conversion for my VTR1000, but I have heard that life of a rear alloy sprocket is very low. If'n that is the case, would I be replacing the rear sprocket without replacing the front sprocket and chain? ..........Is the former really true? Also I am running one tooth down on the front and two up on the rear with a stock 530...Would I shorten the length of the chain at all from stock length(102 links) and how will this effect my rear suspension?
    I still love the smell of burnt racing fuel in the morning!
    who makes a conversion with a steel rear, or is that a custom builder that made one for you? Seams like all conversion kits for a 520 only come in a light alloy....
  1. Slider Recomendations
    By BSR6 in forum General Bike Related
    Last Post: 04-22-11, 01:19 AM
  2. Chrome Plating Recomendations - VT
    By yesterdayze in forum General Bike Related
    Last Post: 04-04-11, 08:52 PM
  3. route or road recomendations?
    By Nate Dawg in forum General Bike Related
    Last Post: 08-20-07, 03:04 PM
  4. Any recomendations for bike alarms?
    By Matt K in forum General Bike Related
    Last Post: 11-18-02, 05:07 PM
