Results 1 to 8 of 8
04 GSXR 750 Oil Change ?
    May 2011
    Springfield, MA
    Hello All,
    I had my bike up on the stands and I was intrested in changing my own fluids and then only bringing it to my shop for end of season and pre season work till I own it a little whild longer. It seems as if I would have to remove the fairing to drain the oil can any one confirm if I "have to or not". As I dont want to damage my clips holding the fairing. Thanks All.
    Lancaster
    Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.2; en-us; DROID2 GLOBAL Build/S273) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
    Usually fairings have to come off to change oil. Change the filter too
    Corey
    Wirelessly posted (Doc sucks: Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_3_3 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8J2 Safari/6533.18.5)
    Glthe GSXR manual says to change the filter eery other oil change, but changing it every oil change wot do you any harm.
    You shouldn't have to remove any OEM bodywork to drain the oil, only if you're changing your oil filter.
    And don't drain the oil on stands. Use the kickstand to drain. Then stand tge bike straight up to drain put any leftover oil that might still be in the oil pan.
    Ray Viernes, Scammer! Ray-Ray's Avatar
    Oct 2009
    Re: 04 GSXR 750 Oil Change ?
    Where are you located, people here are probably willing to help including me....But Jim is right about the whole fairings only coming off when the filter is changed
    Take the side off change the filter and Use OEM stuff.....takes all of 5-10 Min...If that
    Deprived Rider beegz's Avatar
    Southern NH
    I have a GSXR 1K, and I do not remove the fairings for my oil change - even for the filter. Perhaps I have a little more room, but it is possible for me to remove the filter and install a new one by going through the right vent hole. Use a tightly ratcheting ratchet, because you won't have much swing room to get the ratchet to click and lock.
    Facebook: Beegz
    Member smkn-1's Avatar
    manchester
    take off just right side it all you need to change oil i have 05 gsxr 750 which is same as 04
    just did mine sat takes ten mins.
    check anti freeze overflow bottle level it will be right there eye level when changeing oil
  1. 2007 gsxr 750 factory steering damper diy oil change
    By caloots in forum Bike Maintenance
    Last Post: 08-05-14, 09:11 PM
  2. 2007 suzuki gsxr 1000 gsxr stator system
    By frenchy21 in forum Wanted
    Last Post: 07-19-12, 01:51 PM
  3. Replies: 5
    Last Post: 03-22-12, 09:42 AM
  4. Replies: 29
    Last Post: 11-21-11, 06:00 PM
  5. Oil change 06' GSXR 1000
    By duganc1717 in forum Bike Maintenance
    Last Post: 04-19-11, 12:19 PM
