Results 1 to 25 of 26
05 R getin super hot to the touch
    May 2007
    Hartford, CT
    Recently after a short ride the engine and frame of my bike get super hot, so much so that its about to burn my leg. Just last week i changed the oil and topped off the coolant ( the coolant was a diffrent color than the cooland that was in there yellow) but dont see how doing these things would make the bike hot. btw the thermostat only says 185 or so, far from overheating. Any ideas would be appreciated.
    It's 95 freaking degrees out dude, don't worry about it.
    If the coolant temp says 185, you're ok.
    degs
    Member ejoy1220's Avatar
    Mar 2007
    Amherst, MA/Carver, MA
    What kind of bike is an 05 R
    R1
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    Stop riding in shorts????
    May 2007
    Hartford, CT
    Sorry, its a R6, and I never ride in shorts
    May 2007
    Hartford, CT
    It's just weird bechause ive been riding at night lately when its 60 out and never before did the bike get hot like this, even when it was 95 a couple of weeks ago
    Mar 2007
    The frame on my R1 gets ridiculously hot after riding for a while, and on a 90* day the temps will read anywhere from 190-220* while riding. It's just that these bikes were designed to run hot.
    One thing you can do that has given people some relief from the heat is 1) At Water Wetter or other additive to the coolant, and 2) Gutting the cat will also help in reducing the heat.
    R1
    May 2007
    Hartford, CT
    Where do they sell water wetter?
    Southern, NH
    My bike runs at between 175 and 195. In traffic it's up to 220
    You're fine dude
    Mar 2007
    Quote Originally Posted by Noble View Post
    You can grab it any motorcycle shop that carries it, Autozone also carries it, and you can also get it on the internet.
    R1
    Junior Member DucXl's Avatar
    Bristol,RI
    I used to worry when my only watercooled bike would nudge a little over 210.
    BCM Ducati reassured me a few times that they're just fine at 200.And in racing conditions are even fine to 260. Bruce Meyers,the Ducati guru said they're fine to 260.So i've taken his advice.I mean they're just at running temperature at 200 anyways.All of my frames(well,not the old BMW) get hot,especially in hot weather the Ducati will burn
    Edit: oh yeah,keep in mind that the fuel injection meters depending on temperature.Make the ECU think it's cold and you risk poor performance.
    Greg
    Current bikes' :
    '99 X1 Buell
    '00 996 Ducati
    '05 Buell Xb12r
    Ense petit placidam sandman's Avatar
    sema
    Quote Originally Posted by ejoy1220 View Post
    the bikes were NOT designed to run hot!
    they were not designed to run slow around town.
    if you stay around 70mph everthing stays cool, even the subframe (the thing that cooks your legs)
    jim
    "Molon labe"
    Bristol,RI
    I absolutely agree that they weren't designed to cruise.My 996 refuses to even run below 4000 RPM.
    But now the question becomes'...What's a normal operating temperature?
    It's AT LEAST 180 me thinks
    Greg
    Current bikes' :
    '99 X1 Buell
    '00 996 Ducati
    '05 Buell Xb12r
    Lifer nefarious's Avatar
    Jul 2004
    Portland Maine
    hah post up when you start running 220 as a normal temp.... to break under 200 I have to be doing triple digits
    Adobe Certified Expert, Photoshop CS4
    Adobe Certified Professional, Flash CS4
    Mar 2007
    Quote Originally Posted by sandman View Post
    But the normal temperature even when cruising for my year R1 has been reported to be in the 185-200 range. Under normal cruising conditions, with nothing wrong and new coolant, this is pretty much the norm for this bike. The R6 I'm assuming is the same way, but I haven't spent much time over on the R6 forums so I don't really know.
    R1
    Northshore/Beverly, MA
    My TLR runs between 185 and 187 regardless what the temp is out. Stop in traffic and it'll shoot right to 220, fans blasting. Yes, you can cook an egg on the frame too. Most of these alum frames pull the heat quite well.
    Ditto with my TLR. You think yours throws heat? Try sitting on wunna those in traffic on a hot day. That rear cylinder'll fry your boys...
    Lifer union's Avatar
    Blackstone, MA
    Try the RC51 with the fancy side mount radiators. Not only do you get the heat from the motor but you get a nice hot breeze on your legs when the fans kick on at 220.
    James
    Jul 2006
    Hollis, NH
    Fans on gixxers don't even kick on till 220. It's not an Yami, but I doubt there is that much difference in operating temps.
    sema
    my 04 with no cat, a chip and blue ice. runs 165-185 under my normal cruising conditions.
    then again my normal cruising conditions more than likely aren't the same a yours.
    about the only time my engine is below 8k is when i'm coming to a stop and spends most of it's time above 10k
    the blue ice (or what ever it's called) did make a difference as did the chip, stock the bike was running way to lean.
    btw: if it's 85+ i'm not riding the bike i'm fishing.
    jim
    "Molon labe"
    What chicken strip??????? NEWTREADS's Avatar
    West Dover VT
    I noticed after installing the power commander, filter and exhaust that my bike runs really hot. At red lights I see temps in the low 200's after being at speed. U shouldn't have anything to worry about. Has it overheated? If it hasn't worry then.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Not sure but you know mixing types of coolant can
    cause it to deteriorate.
    If you are unsure and know its not just your imagination
    then just drain, flush and refill with new stuff.
    2008 Honda CBR 600RR
    May 2007
    Hartford, CT
    Quote Originally Posted by akira700 View Post
    yea, I was thinking the same. This might be the reason. I mixed green coolant with yellow coolant. I'll drain sometime this week and see how it goes.
    Lifer imkindafkedup's Avatar
    Jan 2006
    Saugus, MA
    in my zx12 water wetter is a must. I'm considering getting a manual fan switch which will also help my heat.
    Worcester, MA
    what types of coolant did you actually mix? It's fine to run hot the way it is, but I'm thinking you may want to drain and refill. Sounds like maybe there was a premix in there and you topped off with straight coolant or something like that. In a lot of cases water is going to keep it cooler than straight coolant. Coolant by design is just to keep the bits and pieces of the cooling system moving, keep it from freezing and minimize the evaporation of water.
    LRRS EX #165 (formerly)
  1. FS: iPod Touch 8gb
    By Yev in forum For Sale
    Last Post: 12-21-12, 09:19 AM
  2. iPod Touch 8GB
    Last Post: 06-04-11, 12:52 PM
  3. A touch more preload?
    By wiggeywackyo in forum General Bike Related
    Last Post: 08-16-09, 12:30 PM
  4. Super newb in Super trouble
    By gix6siege in forum Welcome and Intro
    Last Post: 09-18-08, 08:28 AM
