I have an 07 Husky TE450, and need to bleed the clutch. It has a Magura hydraulic clutch. The manual calls for SAE 10 weight hydraulic clutch fluid.
I have a bottle of the Magura Blood clutch fluid that newer KTMs use. Anyone know if I can use this with my clutch system?
Sent from my SM-G965U1 using Tapatalk
I used simple mineral oil in my 05 Husky 450 Motard. I found that to bleed it I had to remove the lever and or pedal and use a pushrod to get the piston to move all the way. Same for the brakes.
