Results 1 to 17 of 17
180/55 versus 190/50?
    Member Zolden's Avatar
    Jul 2005
    NJ/NY > Central Coast, CA
    My 95 ZX7 came with two dunlop d208's - the rear being 190/50/17. A plug in the rear made me have to get a new tire - I got a michelin pilot power. I told the guys at Razee's that the size was 190/50/17 and that I need one in the same size. I confirmed with them three times that this was the size I needed both on the phone in person, it was on the computer as well.
    I got home and realized they put on a 180/55/17. Is the difference between the two extreme enough to change handling? I seem to be noticing slight differences when in lean, and it seems like when going through corners that theres something amiss.
    This is a hulking 480 lb. old bike. Does it need a 190 to be fully efficient? I'm considering calling razees but I highly doubt at this point theyd change it.
    I hear so many people rave about the 190 to 180 switch. The consensus seems to be the narrower but taller profile makes for quicker handling w/ a comparable contact patch.
    It's funny you posted this, i JUST responded to a thread on sportbikes.net on this very topic
    Holy Crap! What a difference that made! RearRideHeight? - Sportbikes.net
    I think you'll find my response sounds familiar
    Northshore/Beverly, MA
    +1
    Lifer LuvDog's Avatar
    Ashland, MA
    My 2 cents...
    I went from a 190 Dunlop to a 190 Michelin PP... and the turn in was noticeably quicker. Even with the same width.
    Why?
    Probably a lot of reasons...
    1. Different profile from different manufacturer
    2. Different profile from a different "type" of tire... I think the PP has a more aggressive profile than other tires.
    3. The old tire was just worn out.
    Do I think a 180 would turn in any better... not necessarily. Especially since I have a 6" rim on that bike.
    If it were a 5.5" rim, then that would be a different story, since most 190s weren't made to put on a 5.5" rim.
    Also... I think the 180 on a 6" rim isn't quite as effective as it would be on a 5.5" rim.
    2003 ZX7R
    1995 916
    [QUOTE=LuvDog;
    Also... I think the 180 on a 6" rim isn't quite as effective as it would be on a 5.5" rim.[/QUOTE]
    Made a difference on my 6" rim. It's one of the classic make the TLR handle better swaps...
    I'd say it totally depends on the bike. Like TLRMan sez, it's pretty much a 'must do' on a TL-R. Going from the 190 to the 180 on my TL-R was solely responsible for me keeping the bike. When I first got it with the 190 on it, I was SOOO bummed that I thought I had made a HUGE mistake. Coupla weeks later, spooned a 180 on, made a coupla suspension adjustments and it was like night and day...
    I don't think your bike originally came with a 190...
    Lifer ZX-12R's Avatar
    Candia, NH
    Besides the bike, your own preference will come into play as well. My 12R has a 6" rim and came from the factory with a 200. I've tried both a 180 and a 190 on it and have come to like the 190 the best. With a 180, it felt like the bike was falling into corners where the 190 rolls in smoothly and gives me better feedback from the road.
    Dropping to a 190 made it feel like the bike lost 60lbs!
    Good point! It was the exact opposite on the TL-R...
    High maintenance priss
    Central MA
    You guys w/ the TL - have you tried a 5.5" rim w/ a 180? Or all running 6" w/ 180?
    Whatever the stock rear wheel is, I'm running...
    Central MA
    Stocker is 6"
    Wanna Buy me a Marchesini mag 5.5" rim for me, so I can try it out?
    actually, the 180's work OK on the 6".
    Raymond NH
    I've tried both on my 9R, a few times and with quite a few brands. I like the 190 in the tires I'm currently using (Road Attacks). That said, there's far more difference between a worn tire and a new tire of the same size/brand than there is between the 180 and 190. I also found that increasing the rear ride height with 6 mm of spacers on the shock made a much bigger/better handling difference than tire size.
    Jul 2005
    Well after riding near everyday on the new tire I gotta say I definitely notice a bit of a difference. I think its a shitton better to be honest. With the 190 I felt like the bike was really rigid and hard to get down in turns, this really seems to fall into place alot better when going into a turn at a higher speed. It seems like there's just a slight bit of increased agility, but maybe I'm just delusional.
    Cheers and happy fourth.
    Lifer Karaya One's Avatar
    Springfield, Mass
    Try the 190/55.
    Check out my eBay store!
    Dave - Motorace - Michelin
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Your zx7 comes stock with a 180/55. 190/50/55 is not standard.
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    im making friends over there too. just like the NEAR list. speaking of NEAR i havent been there in awhile. maybe ill find some feathers to ruffle over there
  1. Spot versus InReach versus?
    By xxaarraa in forum General Bike Related
    Last Post: 12-14-15, 11:26 AM
  2. Casey Stoner versus F1 car versus "Supercar"
    Last Post: 09-13-14, 10:29 PM
